replacement for torx rear hub bolts?
To start off with, I have a 90 CRX Si
I ended up replacing one of my trailing arms, and had to do a hub swap from one arm to the other. What I'm looking for are replacement bolts for the TORX ones that came in the hub, or something else that's a good replacement?
I found that the bolt is a 1.25X10mm fine bolt thread, but I'm having a hard time with the length.
Can anyone guide me in the right direction?
thanks in advance
thanks in advance
Not sure what the problem is,if you have a torx bolt out measure the length of it and get bolt the same size.
I have used other regular 14mm honda bolts for hub swaps but cant remember where on the car they came from as I have several big tubs of honda bolts.
ZipTieGUy
Feb 27, 2006 06:08 PM
