Honda S2000 Honda S2000
Turbo manifold help
Old May 24, 2010 | 08:02 PM
chasmataz's Avatar
Default Turbo manifold help
Im looking to get 400-450 hp I have greddy gt3076r turbo
650 injectors
aem emu
3mm head gasket
Tial 38mm wastegate
synapse blow off valve
Walbro 255LPH fuel pump
3" exhaust. installed already Was hitting 330 rwhp 10psi
Now I just had a 3mm headgasket installed and my turner can only get 350 rwhp with 15 psi. The question is I have a rev hard manifold and could this be causing the lack of hp? Do I need a racing manifold like pro street?
Old May 25, 2010 | 03:54 AM
ghettocrxsi's Avatar
Default Re: Turbo manifold help
The lack of hp is caused by you lowering your compression with the 3mm headgasket. Hows your injector duty cycle ? What fuel pump?
Most likely though its because of the drop in compression from the 3mm.
Old May 25, 2010 | 03:59 AM
HondaKyle's Avatar
Get larger injectors, ditch the 3mm head gasket, better manifold with a bigger turbo. I dont see why people are still wasting money on GT turbos when you can get better precision journal bearings for cheaper.
Old May 25, 2010 | 05:47 AM
ExVtec's Avatar
Originally Posted by chasmataz
Im looking to get 400-450 hp I have greddy gt3076r turbo 550 injectors fuel pump aem emu etc. installed already Was hitting 330 rwhp 10psi
Now I just had a 3mm headgasket installed and my turner can only get 345 rwhp with 15 psi. The question is I have a rev hard manifold and could this be causing the lack of hp? Do I need a racing manifold like pro street?
Not a fan of the headgasket method, but it's there keep it.
I saw 450whp-500whp on the same boost level w/that turbo, mine was a .82 a/r.
You will need bigger injectors, I'd suggest Injector Dynamics 1000cc, contact Tony Palo @ T1 Race Development.
I ALWAYS recommend tubular manifolds, better pressure ratio's for making "cleaner" power per lb of boost.
Thats the biggest drawback on your setup, make sure you have a 3" exhaust, and at least 2.5" i/c pipes.
Otherwise, sounds like you have a major boost leak, as 15lbs on that setup would see you will over 400whp imo, unless your tuner is a complete hilljack.
I'd also check the health of your motor, with a comp or leakdown test to make sure it's where it needs to be.
Old May 25, 2010 | 07:40 AM
chasmataz's Avatar
Yes I do have 3" exhaust all the way from turbo all the way back just really stumped on why I'm not seeing at least 400 hp
Old May 25, 2010 | 01:49 PM
HondaKyle's Avatar
ID1000s are the bomb
Old May 25, 2010 | 05:26 PM
chasmataz's Avatar
this is what i have, my tuner believes that it may be my manifold not letting enough airflow ?
Old May 25, 2010 | 05:28 PM
chasmataz's Avatar
he is suggesting this. could this fix my problem? prostreet manifold
Old May 25, 2010 | 05:42 PM
HondaKyle's Avatar
^ they went down on price, thats a good one.
buy mine with out wastegate $200. I was making 310 on 8PSI with it.
Old May 25, 2010 | 05:48 PM
chasmataz's Avatar
not bad but im tring to get 400 +
Old May 25, 2010 | 05:50 PM
HondaKyle's Avatar
I was ging to make 400 on it. The full race one is good. I think you have to move your oil filter with that one also.
Old May 25, 2010 | 07:24 PM
JDogg's Avatar
your injectors are too small, 400hp shouldnt really be a problem w/that setup.
Old May 26, 2010 | 05:05 AM
chasmataz's Avatar
I have plenty enough fuel acording to my tuner
Old May 26, 2010 | 05:31 AM
HondaKyle's Avatar
I think you need a new tuner, I bet your injectors are at 80% of what they are good for. You should have need 700ish or just get the ID1000s and never need injectors again...
Old May 26, 2010 | 05:48 AM
JDogg's Avatar
350hp at 9000 rpms needs more than 550's, there is no way around it unless you fuel pressure is all jacked up.
Old May 26, 2010 | 05:31 PM
chasmataz's Avatar
I have 650 fuel injectors , after doing some research today and talking to a different tuner the problem that I'm having isn't fuel pressure or bad tune , its the manifold in the first picture. The holes in it are to small and need to be alot bigger . So after the pro street manifold is installed and tuned I'll post the results.
Old May 26, 2010 | 05:50 PM
The Black Pearl's Avatar
i say you need a new tuner or shop. first he ****s up an ebay turbo now he can't get power with your current setup which should make better power easily......
Old May 26, 2010 | 06:19 PM
HondaKyle's Avatar
making 450 wheel horse is 490 at the crank. you will NOT get that with 550CC injector. your tuners are a joke.
Old May 26, 2010 | 06:24 PM
well he said he's using 650 cc injectors.
using the rule of thumb: divide horsepower goal with number of cylinders and multiply by five..... (450/4)*5= 563 gives you the bare minimum, so 650 cc is still cutting it really close so your point is still valid. if i was his tuner i would also suggest 1000cc, so you should find a new guy to go to
Old May 26, 2010 | 06:27 PM
HondaKyle's Avatar
oh snap! yeah, get the Id1000s! 500 dollars and you will never have to worry about injectors again unless you need a duel fuel pumps.
Old May 28, 2010 | 12:26 AM
riceball777's Avatar
400whp should not be a problem with a rev hard / inline pro log type manifold
Old May 28, 2010 | 07:03 AM
dagle's Avatar
^-- troof. 436whp on a 3mm headgasket + GT3076R @16psi. ILP log manifold
Old May 28, 2010 | 12:32 PM
MIKE@AFITURBO.COM's Avatar
If you are looking for a good deal. We have one of our back up manifolds off our time attack car we are selling. We could make you a good deal on the whole set up. It has to weekends on it. It is one off three setups we rotate on our time attack car. let me know.
You can check it out below:
https://honda-tech.com/forums/honda-s2000-5/afi-turbo-ta-s2000-2779870/
Old Jun 7, 2010 | 09:20 AM
chasmataz's Avatar
can you post the dyno for that set up
Old Jun 7, 2010 | 01:58 PM
Vi3tboy's Avatar
Weird. My base start tune at 7psi made more power than that on a tiny t3/t4 60trim.
I made 400 at 13psi on ID725cc on 92 pump.
I'm running a custom top mount manifold from Full Blown Motors.
The revhard manifolds aren't the greatest but I've seen way more efficient setups come out of logs than that.
My buddy with the ultimate racing manifold got 490 off of 18psi so I agree with most of what was posted.
Your power goals don't require a 3mm HG, get a new tuner, and a new manifold is a bonus.
