4g help!
Old Sep 12, 2002 | 03:03 PM
sweetcarz02's Avatar
Default 4g help!
Well I got a project coming up for a friend and was looking for some help over here from u guys. I am mostly a prowler but let's see what you can do for me.
I am working with a 88 Civic and the motor went bad. He got a new shortblock and I voluntered to do the swap for him. Just making sure their are no shocks. I have swapped a B16 into into a 5th gen. Hatchback and also done a few D series tranny swaps. Anyone have any tips/walkthroughs and such. Thanks for the help.
Old Sep 12, 2002 | 04:34 PM
Home Skillet's Avatar
Default Re: 4g help! (sweetcarz.com)
you'll get a better response is you search the H-T website. not trying to be a jerk but it will save you time.
Old Sep 12, 2002 | 05:23 PM
Louie B.'s Avatar
first off: http://hybrid2.honda-perf.org/tech/4gtech.html
now that that's out of the way, You need to give us some specifics:
what model of civic? Std, DX, Si, Ex? there are going to be some differences.
also, which motor are you putting in? If it is just the shortblock, and you're keeping the same head, intake, tranny, etc. any d- series block will bolt right in (with the possible exception of the ZC.) some d-series blocks are going to give you different compression ratios than others with your head, but none will be dangerously high.
88-89 civics also have a different # of splines on their transmission than the 90 or newer, so if your shortblock is from a 90 up, you'll need to use the 88 clutch, pressure plate, and probably the flywheel as well.
if the motor you're swapping in is a b-series, use the link I provided above.
[Modified by thumpu77, 6:25 PM 9/12/2002]
x2m7noz
K Series
12
Aug 11, 2013 06:37 PM
EF9 JAMS!!!
Aug 22, 2005 05:40 PM
Crimson_Tide
14
Jun 16, 2005 06:04 AM
evilsolb16
May 22, 2005 12:42 PM
