PA '95 Honda Del Sol........Very Quick!!!!!!
Old May 24, 2010 | 01:47 PM
dickie691986's Avatar
Default '95 Honda Del Sol........Very Quick!!!!!!
The motor is a JDM B18C (GSR). Right now I am in the process of putting all brand new suspension bushings, brakes, and ball joints on the car. Car does have brand new tires.The motor only has about 2,000 miles on it. UCF did all the machine shop work and the car was tuned by IMW (John Kerr) using neptune. the first time I ever had the car to the track it ran 8.42 @ 92mhp 1/8mile on drag radials with the turbo setup that is listed below. How ever that turbo setup will not be on it once sold. what you will get is a brand new Garrett gt35r ball bearint turbo with a .82a/r exhaust housing and a 44mm tial v-band wastegate. also will have a brand new ram horn manifold from full-race that I do not have yet. The car once tuned will put down right around 520-540whp. With the 35r set-up. Depending on the drivers driving capabilities this would be a 10sec car in the 1/4 mile. The car also comes with JDM visors, map lights, road flare, rear license plate fillers(license plate lights), ac/controls, trans top switch, four way switch, and front lower fog light switch. also comes with an alpine head unite. The reason im selling the car is to pay off some bills and go back to school. I do have pictures of the car if needed. I would like to try and get $15,000 obo for the car.
Feel free to call or text me with any question at 717-226-2599
• Eagle Rods
• JE 81.5mm Pistons
• ACL Bearings (Standard mains/Race rods)
• Endyn Block Posts
• Endyn Catch Can
• Cosmetic 81.5mm Head Gasket
• NR1 Crank Pulley
• ARP Head Studs
• Skunk2 Pro Series Intake Manifold
• Hondata Intake Manifold Gasket
• Honda Prelude Intake Manifold Studs
• Precision 1200cc Injectors
• Walbro 255 Fuel Pump
• Blox Fuel Pressure Regulator
• B&M Fuel Pressure Gauge
• 12inch "Slimline" Radiator Fan
• Skunk2 Short Throw Shifter
• Skunk2 Shift ****
• Password JDM Shifter Bushings
• Skunk2 Pro-S Coilovers
• Blox Camber Kits Front and Rear
• Blox Rear Lower Control Arms
• Sunpro Gauges (Boost, Vacuum, Oil Pressure, volts)
• LC1 Wide Band With DB Gauge
• Apexi Turbo Timer
• TurboXS Manual Boost Controller
• Nitrous Express Kit (for spraying the intercooler)
• Blox Oil Filter Adaptor
• Blox Vacuum Manifold
• Moroso Baffled Oil Pan
• Moroso Breather (for catch can)
• Skunk2 Cam Seal
• Type-R Throttle Cable
• Type-R Throttle Bracket
• 3inch Exhaust (straight pipe)
• ACT Xtreme Clutch Kit (AI4-XTG6)
• Skunk2 Titanium Retainers
• Skunk2 Dual Valve Springs (Tuner series)
• PEAKBOOST TURBO KIT:
o PeakBoost Stainless Steel Equal Length FTW manifold made out of 304 8 gauge stainless steel
o Garrett T3/TO4E Turbocharger
o Tial 38mm Wastegate
o PeakBoost(Garrett core)24x6x3.5 Intercooler (2.5" inlet and outlet)(Bead rolled)
o Tial 50mm blow off valve
o (Aluminum)MANDREL BENT MIRROR POLISHED complete 3 piece 2.5" charge piping with bead rolled ends to prevent piping blow offs
o 3inch Stainless downpipe with stainless flex section
o wastegate dumptube
o Stainless oil feed (-3) and oil drain (-10) lines
o Weldless 100% leak free oil drain line
o Strong T-Bolt hose clamps
Old May 24, 2010 | 01:48 PM
LSVTEC426's Avatar
Default Re: '95 Honda Del Sol........Very Quick!!!!!!
damn 15k? well hope u get what your looking for. this needs pics
Old May 24, 2010 | 04:18 PM
gotboost420's Avatar
hard to sell with zero pics
Old May 24, 2010 | 10:10 PM
srt4mike's Avatar
Old May 30, 2010 | 10:41 PM
SolAssassin's Avatar
I really don't think you're going to get any offers without pics! This is like the carfax commercial where the dealer busts out the "car fox" LOL
Old May 31, 2010 | 12:06 AM
Pictures will be up soon. Iv been really busy since this post
Old May 31, 2010 | 12:50 AM
DrGrEeNtHuMb's Avatar
"yeah I'll show you the car flaps!"
lol glws
SI_frankenstein
Jan 21, 2012 09:11 PM
dickie691986
Jul 14, 2010 11:42 AM
dickie691986
Jul 13, 2010 05:57 PM
hondaholic_7
Dec 24, 2009 06:28 PM
