Transmission & Drivetrain Gearboxes, Differentials, Clutches
S20 tranny giving out problems???
Old May 24, 2010 | 01:41 PM
frynman's Avatar
Default S20 tranny giving out problems???
S20 tranny on d16z6 engine.
Just replaced clutch master cylinder with omini's version, bleed it and I'm having a hard time putting it into gear. When car is lifted it's easy but still is hard with grinding in reverse. Before swaping the old stock master cylinder out it was going into gear but just about all my gears were having a hard time especially 1st, 2nd and reverse while 3rd and 4th would grind every once in a while when immediately switching gears. Also replaced the cylinder slave and bleed it and still won’t go into gear or grind but will while lifted front tires off ground. HELP?
allmotorgsr98
12
Jun 5, 2011 10:25 PM
97BB6Type-SH
Aug 16, 2006 06:03 PM
517vwj_boi
Mar 14, 2006 09:35 PM
ludelvr
Sep 19, 2003 05:34 PM
