whats needed to put ac in a eg h22
guy on one of the local forums in nc did this write up
http://www.carolinahondas.com/instal...-h22-swap.html
What was wrong with the info in that other thread? Not enough pictures?
first off take off your front bumper off to make it easy to get to everything.
then remove your condencer fan because you cant use it.its not enough room for it.
buy you a 10in. slim fit fan and mount it on the front of your condencer toward the front bumper.and cut the factory plug off your old fan and put it on the new one.check to be sure when you wire it up that it is pushing the air thru the condencer not pulling
use all your factory a/c stuff except the compressor and bracket.then you just use the h22 a/c bracket and compressor.your a/c lines will bolt right to that compressor.
its going to be really tite fit but it will work.just buy your factory a/c belt for the h22.put your front bumper back on.and charge and check for leaks
thats it your done you got a/c on your h22 swap.told you it was simple.i love it.
Trbospnkr
Jul 7, 2003 09:31 PM
