Suspension & Brakes Theory, alignment, spring rates....
Car pulls left when acelling and moves right when decelling
Old May 24, 2010 | 11:31 AM
cfwthb_94's Avatar
Default Car pulls left when acelling and moves right when decelling
When I was at the track at an IFO event a month ago the last two races I noticed when I was backing out of the pits, at full clock, the front end started to make a clicking sound and was more difficult to turn. Now while driving when I'm getting on it, from a little to a lot, the car pull's left very hard and then when I let off the gas it will shoot back to the right. What would cause this.....axle, differential, or steering rack, etc? I've put it up on a lift and everthing seems to be nice and tight as far as bolts that are apart of the suspension go. I replaced the passenger side axle today and it's still doing it. It was more difficult to remove this time than in the past, a lot more actually. Any help or idea's would be appreciated. Thank you
Old May 24, 2010 | 06:03 PM
JustOneOrTwoPosts's Avatar
Default Re: Car pulls left when acelling and moves right when decelling
try the driver's side axle. It would make sense that the driver side has failed if you are accelerating and it pulls left and vice-versa.
Old May 30, 2010 | 02:25 PM
cfwthb_94's Avatar
Thank you I will have to try the drivers side axle. Passenger didn't do anything
GdmLaz
Jul 11, 2013 03:10 PM
tooslohatch
May 15, 2012 09:04 AM
'00_GSR/R
Suspension & Brakes
Sep 28, 2010 07:32 AM
Slosc2
Apr 4, 2009 06:20 PM
skateboard_ej8
Oct 7, 2008 11:50 AM
