Factory strut tower brace
Old May 24, 2010 | 08:47 AM
sgraham01's Avatar
Default Factory strut tower brace
Has anyone ever added the (95-97?) V6 Accord factory strut tower/firewall brace to a 4 cyl car? I have a '94 4 cyl accord and would like to add the factory brace, but it's starting to look like the strut towers and firewall may be slightly different on the v6 car. Just wondering if anyone has done this. Looks like it would be more effective than a conventional tower brace since it attaches to the firewall as well. thanks
Old May 24, 2010 | 09:00 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Factory strut tower brace
The v6 has a different front end, not to mention the engine bay is flipped around. I wouldn't use it.
Just get a nice aftermarket one. I only paid $70 shipped for my Cusco one.
Alternatively you can get the FFC strut bar, which also attaches to the firewall. It's available on HondaSociety.
Old May 24, 2010 | 05:00 PM
uberEFtuner's Avatar
On the 92 Civic the firewall brace seems silly because their is a small brace behind the bolt holes. You can push on the firewall and make it flex there. So I wouldn't waste money on a 3 point.
Old May 25, 2010 | 12:59 PM
accordhybrid's Avatar
We are not talking about civics here, we are speaking about accords. Also the FFC 3 point strut bar that MuffinMan is talking about has a bracket that goes behind the firewall for added strength.
Old May 27, 2010 | 05:53 AM
overboostin's Avatar
should work the front end was just made longer from the front of the shock tower to the headlights to give proper room for the motor . same area from shock tower to firewall and same distance between both shock towers... you would just need to add the holse in the shocktower add the bolts to hold the bar down . fyi the 94-97 accord and 97-99 cl share the same front 4/6 besides being longer after the shocktower
when they put the v6 in they swap the body mounts
Old May 27, 2010 | 06:13 AM
sgraham01's Avatar
the bolt holes were my main concern
Doesn't look like the threaded holes are in my strut towers. I don't really want to drill any holes so I guess it may be better to go aftermarket.
***Could someone with the stock strut brace please post some pics of the mounting points?
Old May 27, 2010 | 06:33 AM
http://www.hondaautomotiveparts.com/...RONT+LOWER+ARM
You don't have those on your 4cyl
Old May 27, 2010 | 07:52 AM
sgraham01's Avatar
Originally Posted by TheMuffinMan
thanks, i actually got the idea from that very photo. I was just wondering what it looked like mounted in the car and exactly where the bolts attach if anyone could post a pic of the strut tower. i found a pic online, but from a bad angle. thanks for the info.
Old May 27, 2010 | 10:01 AM
Just go on AutoTrader
You can see where it attaches behind the strut itself.
Old May 27, 2010 | 10:08 AM
better to get an aftermarket option.
Old May 27, 2010 | 10:10 AM
ill get some pics for u off mine
Old May 27, 2010 | 10:17 AM
Old May 27, 2010 | 10:30 AM
CD7_Accord-SiR's Avatar
heres a picture of the FFC 3 point strut bar for the 94-97 accord
Old May 28, 2010 | 07:35 PM
Hella clean engine bay and that's a bad *** strut bar
NC-B17A
Oct 24, 2003 06:27 AM
EX-JAY
Oct 21, 2003 11:49 PM
inda90coupe
Jun 21, 2003 03:30 PM
