Blower Motor AGAIN After Recharge
Old May 24, 2010 | 06:14 AM
Rik Emmett's Avatar
Default Blower Motor AGAIN After Recharge
Hi,
Installed a new blower motor last July after checking all fuses, etc, and it ran perfectly until last week. I charged the AC, as it was low, and it worked beautifully for 2 drives of 10-20 mins. Then it suddenly stopped blowing. I checked both the fuse under driver's side and relay under hood, replaced both with ones I knew to be working- still no blowing. I can hear ac kicking on, but no blower.
Could I have blown something out during the recharge? Or are blower motors sometimes cheap and konk out after about a year (It's MN, so it gets used often.)? Thoughts?
Thanks,
Daryl.
Old May 24, 2010 | 07:02 AM
phootbag's Avatar
Default Re: Blower Motor AGAIN After Recharge
Did you perform a voltage drop across the blower motor?
Old May 24, 2010 | 07:56 AM
Rik Emmett's Avatar
Oops.
Thanks, phootbag. As I was getting ready to do just that, I realized that the hot + humid weather had caused the elec tape between the connecting wires to loosen, and the wire had slipped out of the boot. I reconnected it (paying more attention to tightening the boot properly), & re-taped, all the while hearing my father's voice echoing in my head: "Always making things harder than they need to be, huh?"
Problem solved.
Thanks again!
1320whtrex
17
Dec 2, 2025 03:47 PM
stacyorndorff
Apr 26, 2017 10:18 AM
andlude
Aug 8, 2007 02:34 PM
Arsenal
Dec 14, 2005 11:16 AM
