help with 76mm vitara pistons
You should check the FAQ for the compression calculator to verify that the compression ratio with your specific setup will be what you want (my thinking is that vitara pistons in a DOHC ZC will yield an extremely low compression ratio). If it's what you want then all you need to do is have your block overbored and honed to match the new pistons and have the pistons installed onto whatever rods you are using. If it's not what you want, select an appropriate piston and proceed as stated.
if you want info on vitara pistons here is a e-mail address. info@fjdistributors.com he is a tech on the vitara pistons. that all he builds
hondaluver12
Feb 17, 2009 05:51 PM
xparalandrax
Feb 21, 2008 06:28 AM
89civichatchback
May 28, 2003 08:38 PM
