Suspension & Brakes Theory, alignment, spring rates....
HELP! F@#$%ED up wheel jerking
Old May 23, 2010 | 11:27 PM
JapRat's Avatar
Default HELP! F@#$%ED up wheel jerking
alright so im having an interesting problem with my front end. I have a 1997 civic dx. Its slammed but i haven;t had a problem up until now. driving along, my wheel will pull a bit to the rightwhich is normal because i need an alignment. but recently it starts to get worse and then speratically and ferociously jerk to the right. its also making a bit of a noise but that too is intermitant. If I pull over, cut my wheel all the way to the left and go in a circle, the problem subsides briefly then returns. This happens on and off. The secondary part of this inquiry has to do with cv axles. I needed a new one on the right side about a month 1/2 ago and my supposed honda-knowledgeable pal reassured me that a cv axle from an eg would work. skeptical was i but there were no issues until now. help...
Old May 24, 2010 | 01:28 AM
ticaaal70's Avatar
Default Re: HELP! F@#$%ED up wheel jerking
What suspension upgrades do you have...
Old May 24, 2010 | 10:22 AM
JapRat's Avatar
just coil overs
Old May 24, 2010 | 11:13 AM
JDogg's Avatar
eg and ek axles are the same
if the steering wheel is jerking the axle is probably bad
Old May 24, 2010 | 08:26 PM
alphalanos's Avatar
camber and toe angles have a big impact on pulling. If the tires are worn from bad toe that makes it worse. get it aligned with 0 toe and see how it feels.
Old May 27, 2010 | 09:58 PM
02 accord's Avatar
Also check for any loose ball joints. That could cause jerking when going over bumps.
J_Roc41
Feb 20, 2009 12:14 AM
buzlink
16
Oct 18, 2007 07:41 PM
cmyrex
Nov 14, 2006 08:28 AM
Takumi Fujiwara
Feb 25, 2004 09:17 AM
elmo908
Jan 8, 2004 06:08 PM
