turboing my car what else do i need?
Old May 23, 2010 | 07:09 PM
93delslow315's Avatar
Default turboing my car what else do i need?
im just trying to piece everything together for me b16a del sol what else would i need besides
ebay turbo kit (i know its not the best but im just looking to have fun with it)
walbro 255 fuel pump
dsm 450cc injectors
fuel pressure regulator
strong enough clutch to handle the power
hondata s300
and a tune?
Old May 23, 2010 | 07:35 PM
Adamvanxxx's Avatar
Default Re: turboing my car what else do i need?
Just a quick search in the forced induction section to double check.
Old May 23, 2010 | 07:49 PM
l0nest4rr's Avatar
a resistor box for your injectors and a boost gauge, and probably the rest of your exhaust piping
Old May 23, 2010 | 07:51 PM
l0nest4rr's Avatar
oil filter, new oil,
Old May 23, 2010 | 08:07 PM
earfejj's Avatar
Is this a daily driver?
Old May 23, 2010 | 08:29 PM
not anymore its not i ended up buying a jeep for the daily driver. del sol is gonna be a track car from now on
Old May 23, 2010 | 09:27 PM
xide_12's Avatar
what are you power goals?
I would also definitely get it tuned with out a doubt, and get arp head studs
Old May 23, 2010 | 09:35 PM
earfejj's Avatar
Well what kind of track driving?
autox?
Strip?
Old May 23, 2010 | 09:47 PM
Linked's Avatar
hopefully he wont need any if its not a built block and he wont tear it down during the swap
Old May 23, 2010 | 10:10 PM
earfejj's Avatar
Exactly. If you are actually going to build a track car. Get some ideas from the forced induction thread. LOTS of info. Tear it down and build it up.
Old May 23, 2010 | 10:13 PM
98civdx's Avatar
Master Detailer
This just me howver id throw some pistons/rods. rod bolts,headstuds and a thicker headgasket.
Stock motor will work just fine though. But rod bolts/headstuds and head gasket should be added.
Old May 24, 2010 | 12:56 AM
ticaaal70's Avatar
Make sure that ebay kit fits...
Old May 24, 2010 | 02:41 AM
just looking to have it on the strip , only expecting maybe 240whp one 7-8psi . in time i will definately go with low pression pistons and h beam rods. redo all the gaskets and what not
Old May 25, 2010 | 06:47 PM
l0nest4rr's Avatar
^ there you go
Old May 26, 2010 | 12:09 AM
chewyv's Avatar
pm4nudes
you havent told us what comes in the turbo kit?
Old May 27, 2010 | 08:25 PM
http://cgi.ebay.com/ebaymotors/T3-T4...Q5fAccessories
heres the kit , im pretty sure everything is in there.id like for it to be a track car and on the weekends to. in the long run im starting to think maybe il get the hondata s300 , pistons rods , head studs and then start with the turbo and supporting mods
The Low Sol
Jun 3, 2012 03:44 PM
BlueVxIDelSlo
11
Apr 12, 2011 07:55 PM
Red94Sol
Mid-Atlantic (Sales)
Jul 10, 2009 06:48 PM
1LowSol
Feb 14, 2009 09:48 AM
rysingsun86
Oct 12, 2005 05:05 PM
