B/D series torque mounts
Old May 23, 2010 | 02:16 PM
Dekorum's Avatar
Default B/D series torque mounts
Are B and D series torque mounts different from one another? I'm swapping a B18C type R into an EG and I was able to use my D series passenger side torque mount, but I never had a driver side torque mount. I want to use one now, so do I have to get a B series or a D series torque mount for the drivers side?
Old May 23, 2010 | 02:32 PM
deadazleep's Avatar
Default Re: B/D series torque mounts
if you just mean the rubber mount, then i took one off a junkyard eg coupe and put it on my b16swapped 93 hatch fit like a glove
Old May 23, 2010 | 05:51 PM
Dekorum's Avatar
I think its rubber, whatever all of the mounts are made of... I think its part metal..
anyone else know?
Old May 23, 2010 | 05:54 PM
98civdx's Avatar
Master Detailer
Use the one from the car. So d series.
Old May 23, 2010 | 06:02 PM
Dekorum's Avatar
Alright, if it bolts up to the ITR motor that would be great.
Old May 23, 2010 | 06:08 PM
Vindicator9000's Avatar
318 Curves, 11 miles
Yes, use D series. It'll work just fine.
The B series ones have an extra metal tab on top that causes them to not line up with the holes in the Civic body correctly. At least, that was the case with the B mounts that came with my swap. I just pumped the D mounts full of polyurethane and threw them back on.
Old May 23, 2010 | 07:08 PM
Dekorum's Avatar
Ok, thanks a lot!
JPerkMr954
Mar 9, 2011 02:50 PM
delboost
May 20, 2008 08:42 AM
7808
Mar 1, 2007 02:10 PM
poop32145432
Feb 19, 2004 09:02 PM
