Suspension & Brakes Theory, alignment, spring rates....
Omnipower coilovers for EF fit on EK?
Old May 23, 2010 | 02:13 PM
cliniCrx's Avatar
Default Omnipower coilovers for EF fit on EK?
Hey guys, just a quick question. A buddy of mine has a set of omnipower drag coilovers from his 91 crx that hes selling. I have a 96 civic hatch, and would like to buy them but i want to be sure they will work. I seem to remember people using ef suspension on ek's and it working fine, but figured it best to ask the suspension experts on here how well this would work.
Thanks in advance.
Old May 23, 2010 | 03:51 PM
user 98292739's Avatar
Default Re: Omnipower coilovers for EF fit on EK?
the front will fit fine. I used EF forks anyway.
The rears wont fit without spacers. 6mm i think it was. So i used 6 washers on each side to make them work.
Old May 23, 2010 | 04:47 PM
cliniCrx's Avatar
so i could use the fronts with the ek forks like normal also, using ef forks would just bring me lower i assume?
and when you say spacers for the rear, you mean where they bolt to the lower control arm?
Old May 24, 2010 | 04:58 PM
yes it lowers your car even more which i didnt mind
and for spacers i just used washers at a hardware store meassured out to 6mm I THINK that was it i know it was 6 a side. and yes so it would be coilover fork-3 washers-LCA-3 washers-coilover fork
memo_ej8
May 29, 2013 09:32 AM
yellowjdmcrx
Apr 22, 2008 12:59 PM
rjones
Suspension & Brakes
Mar 4, 2008 02:16 PM
RMXmitch
Jan 2, 2007 07:34 PM
MotoCARR
Suspension & Brakes
Mar 8, 2006 11:49 AM
