96 EK STROKER KIT NA E85
YEAR:1996
MAKE:Honda
MODEL:Civic hatch dx
MILES:1*****
PRICE: $6512.99 OR BEST OFFER, keep your negitive comments to yourself.
Contact me through pm and I'll message my number if intertested.
Decided to sell my civic so here it is. Its a NA build b20V with the golden eagle 95mm crank stroker kit. Motor compression is 210 all cross all four cylinder so its pretty healthy. Runs solid and pulls hard. I do suggest getting a retune because the orginal ecu was just stolen but I did have old base map from when it was tune at Map by jorden. If it doesnt sell by late june/july I'll get it retune and keep it. Also its tune for E85. Shell wise its pretty clean. None to little surface rust. I did break a lca and it scrape my quarter panel and there is a small paint chip there. NO TEST DRIVE UNLESS YOU GOT THE CASH, I of course will be the one driving it for test drives.
Motor/engine related
b20 block
golden eagle stroker crank
eagle rods
84mm cp stroker pistons 11.5:1
cometic head gasket
golden eagle lsvtec line kit and sandwich plate
gsr head pnp (Dan Paremore Racing)
skunk2 intake mani pnp (Dan Paremore Racing)
skunk2 70mm throttle body
skunk 2 stage 2 cams
skunk2 dual valve springs and retainers
aem cam gears
750 rc injectors
aem fuel rail
hondata intake mani gasket
Gsr transmission (no grinds)
endyne breather kit
autozone axles lifetime warrenty
Hytech Replica Header
Act 6 pluck with 8lb flywheel (less than 7K)
JDM blue valve cover
JDM ITR crank pulley
Innovative Mounts
short throw shifter
255 fp
Exterior/suspension
ctr replica rear lip
ctr replica spoiler
15" Rota grids
Tien Flex
Hid retrofit headlight(tsx projectors)
99 front/back conversion
Cons
Front bumper rock chips/small crack maybe need to be paint but it didnt bother me.
window pin was missing so the window handle is loose
Small paint chip on one of the panels
Car is dirty and I didnt wash it yet but here are pictures/more pictures will be uploaded after I stop being lazy.
MAKE:Honda
MILES:1*****
b20 block
eagle rods
cometic head gasket
aem cam gears
750 rc injectors
aem fuel rail
endyne breather kit
Innovative Mounts
short throw shifter
255 fp
Exterior/suspension
ctr replica spoiler
15" Rota grids
Tien Flex
Cons
Spade
21
Jul 11, 2002 08:38 AM
