93 civic with GSR idle/bogging issue?..
Old May 23, 2010 | 01:09 PM
cdjr636's Avatar
Icon2 93 civic with GSR idle/bogging issue?..
Well her it goes..
I have a 93 civic obd1 conversionm p28 ecu. Ran fine then it started hard to start then wouldnt start. had to move it so cranked over popped clitch to move it. Then pulled distb cap off my rotor button backed off destroyed my inside replaced all wont run.Put new belt on timing gears are in sync with each other and in with the crank. Car will sometimes start rtuns decent until it warms up then sputters and bogs. under a load while driving its worse. Sometimes will have to pull the bolts out of the distb fully retard it to start put back in norman posiiton will run. will bog at low idle or fast rev rev slow will go to rev limiter.. tried another map sensor no go. I think its the distb or some sensor it is not throwing any codes.
Help!! im out of ideas:(
Old May 24, 2010 | 01:25 AM
lex09's Avatar
Default Re: 93 civic with GSR idle/bogging issue?..
check the ground on the thermostat housing. its a sensor ground for all the distributor internals
i had the same thing happen to me, turned out it was a bad ground. give it a try.
Old May 24, 2010 | 01:10 PM
cdjr636's Avatar
Will do, Thanks Any other ideas anyone?...
Old May 26, 2010 | 05:04 PM
cdjr636's Avatar
Well, i checked the ground it was tight. Any other ideas?....
Old May 31, 2010 | 12:03 PM
cdjr636's Avatar
Bump....Anyone
Flipskater2491
Engine Management and Tuning
Mar 11, 2015 01:37 PM
Omar Heredia
16
Sep 13, 2012 01:31 AM
93eggo
Dec 6, 2010 12:23 PM
91tegrals
Jan 10, 2010 02:54 PM
shynomi
May 19, 2005 08:52 PM
