ls/vtec no compression cyl. 1
Old May 23, 2010 | 12:24 PM
kmac714's Avatar
Default ls/vtec no compression cyl. 1
i have a low compression ls/v built for turbo, heres the deal...theromstat stuck closed head gasket melted car still ran fine but with an oil leak. after puttting in the new cometic hybrid gasket, i had a no start i have spark, 20-160-160-160 compression readings. took the head off no bent valves n cracks in the head cam lobes r fine motor is brand new only 11k on the build so i wouldnt think rings. Anyone got any idea on what else to check or do?
Old May 23, 2010 | 12:49 PM
nsxter's Avatar
Default Re: ls/vtec no compression cyl. 1
did you happen to check the block and head to see if they are straight
Old May 23, 2010 | 01:28 PM
kmac714's Avatar
yea when i took the head off i cleaned both up n they r not warped
Old May 23, 2010 | 02:36 PM
slowcrx954's Avatar
leak down test!it will tell you everthing!!
punkracer
Dec 2, 2005 08:19 AM
slthatch
Sep 3, 2005 03:29 PM
blackhatchb20
Dec 1, 2004 05:45 PM
t3hatch
Nov 8, 2004 09:49 AM
MugenGSRb18
Sep 7, 2004 12:43 AM
