d15b2 to d16a6 question and valve seal question
Old May 23, 2010 | 11:34 AM
CRXguy_88's Avatar
Default d15b2 to d16a6 question and valve seal question
ok so i might be buying a complete d16a6 swap to switch for my d15b2. question is with the dpfi to mpfi i would have everything i need? (manifold, injectors, si harness, ecu, ressistor box {if theres more plese add}) and the only thing i would need to do is combine the harness' together? also the head on the motor has bad valve seal guids.. so the guy says.. does that mess up the block at all? if not then its all good cuz i found someone selling an a6 head with an aftemarket cam cheap.. if i can have these answered i can jump on this and buy it before its gone.. ive already miss out on one complete a6 dont wanna do it again.. thanks HT
Old May 23, 2010 | 02:40 PM
freydaddy's Avatar
Default Re: d15b2 to d16a6 question and valve seal question
if you are gettin it cheap enough, have the head worked with new seals, a new Z6 gasket and call it a day. all about $300.
Old May 23, 2010 | 02:44 PM
CRXguy_88's Avatar
ok thats not too bad so does it cause any stress on the block at all? and how much would a slight bore over cost if i give them the pistons? any idea? if not is cool thanks for the reply
Applefrittere
Aug 3, 2018 03:17 PM
delbert
May 14, 2009 09:10 PM
4DRmafia
Dec 29, 2005 08:58 PM
reXem
Jun 25, 2002 09:04 AM
