94 vtec accord axle problem
i have a 94 manual transmission v tec accord, im trying to change out my axles, i got all the bult out already on both side and so far the passenger side came out good but the driver side is still stuck, is there anything else i have to pull off on the driver side?
It's the exact same. Just make sure you don't pull that seal off the transmission. I used a big flathead screwdriver and it popped right out. I have done axles on these cars 5 times, both sides.
manual trans has an intermitent shaft....the intermintent shaft itself is bolted to the block but the axle should come right out of it with a little force
Lynn Porter
Aug 11, 2015 10:29 PM
