need advice
Old May 23, 2010 | 07:52 AM
young geezer's Avatar
Default need advice
so i think my piston rings are going out on my motor. my motor pulled 175 whp and i want to add llittle bit more power to it. i am thinking about putting some CRT pistons on for little bit more power. what you guys think. should i add CTR pistons or ITR pistons back in there.
Old May 23, 2010 | 08:16 AM
soulassassin13's Avatar
Default Re: need advice
Go with P30 pistons... a little bit more compression than stock and no valve clearance issues. I am waiting to put these in my B18C*R. I wouldn't put new pistons in unless I had some good supporting modifications though.
WDG_729_ITR's Avatar
I'm typically in favor of sticking with the stock internals--unless you're going to be making too much power for them to handle...otherwise, it was meant for the car, and others before you have made plenty of power by upgrading around it.
Old May 23, 2010 | 08:42 AM
what CR does the p30 pistons have, i always thought ITR has higher CR. my goal is to reach around 190 whp all motor. i am even thinking about skunk 2 cams or CTR cams.
Old May 23, 2010 | 02:03 PM
You can make 190whp with bolt-ons...
Old May 23, 2010 | 03:42 PM
^ True story. I did it. 194hp/150tq with a Hytech big tube header, Hytech twin-loop exhaust, Mugen intake, and Hondata S300. I can't wait to put in my new P30 pistons, Skunk 2 pro 1 cams, Toda timing belt, Endyn IM, and 310cc injectors.
Last edited by soulassassin13; May 23, 2010 at 03:45 PM. Reason: Wasn't finished yet...
Old May 23, 2010 | 06:14 PM
PaulMc's Avatar
Painfully Stupid
That's a nice amount of torque. No sarcasm.
Old May 23, 2010 | 06:28 PM
thundernoodle's Avatar
damn 150ft/lbs
jap305
Jan 3, 2012 03:33 PM
skata89
Apr 24, 2008 11:06 AM
PROJEKT DB2
Sep 29, 2006 09:18 AM
mustbenu
May 21, 2004 11:25 AM
Stryker908
Nov 13, 2002 12:29 AM
