ek tranny
Old May 23, 2010 | 06:28 AM
ef-hatchcrap's Avatar
Default ek tranny
Ok I have heard mixed opinions about this. I have 95 del sol boosted the input shaft bearing is bad. Can I take a tranny out of a ek and put it in my del sol.
Some say it bolts right up and some say that the tranny mount is diffrent and it will sit on the wrong angle.
Can some one please confirm or bust this myth for me. I'm a ef guy so this is my first del sol
Thanks in advance
Scott.
Old May 23, 2010 | 10:05 AM
LS-turboner's Avatar
Default Re: ek tranny
uhh, there arent ek trannys. d series and b series. its mounts that are different.
Old May 23, 2010 | 10:21 AM
I know that I meant a trans out of an ek! I wasn't sure about the mounts. Thats why I aksed the question that I did
Old May 23, 2010 | 10:57 AM
20-EM2-05's Avatar
Transmissions out of EK's are B series. No they will not fit.
If you are wanting a D16Y7/Y8 trannys sure. They will fit and bolt right up.
Give us infos on your motor also. A boosted del so can mean boosted. LS/GSR/B16/ITR/D16Z6/D15B....etc.
Old May 23, 2010 | 02:15 PM
lol you guys hilarious I know what a b-series is and I know what a single cam is. The only b series in a ek is the si.
Its a d15b head and a y7 block with arps and yes the one by the vtec solenoid is longer than all the rest.m
Ram horn with a t3/t4 50 trim, delta 2 waste gate, greddy type rs bov, and greddy emange tuned on 12psi
Old May 23, 2010 | 03:36 PM
20-EM2-05's Avatar
Well you just said "EK" and you didn't said what motor you had in your car. Technically the SI's are EM1's well yeah. Enough with that.
Seeing since you said you had a D16Y7 bottom I don't find a reason why they wouldn't bolt right up. A D16Y7/8 should bolt up with no problem.
Searching would have done the job for you also.
Old May 23, 2010 | 03:41 PM
98civdx's Avatar
Master Detailer
NO, this is incorrect!!
If the car has a d seres in it yes,
if the car is a b series the only B sereries "EK" is 99-00 and it will still work.
Old May 23, 2010 | 03:51 PM
20-EM2-05's Avatar
You are talking about the EJ6/EM1. EK's are B16A/B from japan.
Not trying to be an *** but he didn't state his motor he had. So how the hell would I know if he was talking about a single cam or dual.
And you are saying a B16A2 tranny will bolt up to a Y7 bottom?
Old May 23, 2010 | 04:30 PM
kaboom954's Avatar
EK is the EDM/JDM Civic and they came in both B & D series.
Example: EK3 EDM D15Z6, EK3 JDM D15B, EK9 JDM B16B
The USDM 99-00 Civic Si is not a EK, it's a EM1
To OP the following transmissions will bolt up, but some will run shitty and some wont. Any 92-95 USDM DX/VX/CX/Si tranny or any 96-00 DX/LX/EX/HX tranny.
The D16Z6 transmission (P20/B000) is a good one.
The D16Y8 transmission is also good.
Out of the two the P20/B000 is slighty better due to the shorter ratio in 2nd gear.
Also the P20/B000 comes in two forms. You have the one from the 92-95 Civic EX and the one from the 92-95 Civic Si & 93-95 del Sol Si. The one for the Civic Si and del Sol Si have a 5th gear ratio of 0.702 which is slightly better than the EX ratio of 0.750
/Thread
Old May 23, 2010 | 04:56 PM
98civdx's Avatar
Master Detailer
You are talking about the EJ6/EM2. EK's are B16A/B from japan.
What? No i am not. You said ALL Ek's are b series and wont fit, and thats complete bull ****.
And no b series and d series are complety different.
EVERY 96-00 IN THE US (EXCEPT 99-00 SI) CAME WITH D SERIES!! Em2's arent even in the same generation retard.
Old May 23, 2010 | 08:19 PM
20-EM2-05's Avatar
Damn typo sheesh. All butt hurt off no reason.
I was just trying to help the OP, not you.
I'm a retard? Lmao. Nice insult. You hurted me berry very much.
Old May 23, 2010 | 09:43 PM
98civdx's Avatar
Master Detailer
Yea, you helped.
OP you can use any d series tranny, 92-00 will work. eg/ek whatever you want to call it. just use the mounts from your del sol.
Old May 24, 2010 | 03:15 AM
k that all I needed to know The tranny is out of a 98 civic ex so it should have some decent gear ratios. I now I have a vx tranny now and it falls out of boost when I switch gears.
One more thing I will have to youy my del sol tranny mount correct not the ek tranny mount
Old May 24, 2010 | 09:52 AM
98civdx's Avatar
Master Detailer
Just use the del sol mount.
method520
Mar 26, 2009 11:00 AM
JDM_Andrew
Dec 27, 2006 04:00 PM
tbud454
Feb 13, 2004 08:35 PM
