B16 EF guys.. What air intake?
Old Sep 12, 2002 | 01:22 PM
SiZ's Avatar
SiZ
Default B16 EF guys.. What air intake?
Hey.. I'm just wondering what kind of intake tube you guys are using if you keep your battery in the stock location. I have a CAI from a 95 Si that was given to me for free, but the only way it will fit is to move the battery it looks like. I don't want to have to do that.. Lazy man hate work.
Anyone know what I can do and keep my battery where it is?
Thanks.
Old Sep 12, 2002 | 02:01 PM
EP3_05's Avatar
Default Re: B16 EF guys.. What air intake? (SiZ)
I run an iceman CAI for the 88-91 civic/crx Si. It fits fine and I didn't have to move the battery.
Old Sep 12, 2002 | 02:29 PM
andrew dc's Avatar
Default Re: B16 EF guys.. What air intake? (91civic)
i run a 99 si.. battery relocated to trunk
Old Sep 12, 2002 | 02:40 PM
Brandon Chun's Avatar
Default Re: B16 EF guys.. What air intake? (CRX25)
I ran a short ram intake. You could relocate the battery or get one of those Optima batteries and it would fit.
Old Sep 12, 2002 | 03:17 PM
SiZ's Avatar
SiZ
Default Re: B16 EF guys.. What air intake? (Brandon Chun)
Whats an Optima battery?
The thing that I wondered about running the 88-91 Civic intake was is it going to hinder pefromance a bit because the intake piping is smaller for the D16 than the B16?
Old Sep 12, 2002 | 03:22 PM
Malgerus's Avatar
An "optima" battery is the brand name. It is just a battery. I'm not sure if it's smaller...? The 88-91 piping is a little smaller than than the B16 one, so, that usually means more low end torque, but less breathing at high RPM.
Old Sep 12, 2002 | 03:23 PM
......'s Avatar
You need an AEM cold air, for the year of your car. My car is a 1990 and that is what I use.
Old Sep 12, 2002 | 03:45 PM
primoEF's Avatar
91 Teg intake tube
Old Sep 12, 2002 | 04:15 PM
Phatwhippin_CRX's Avatar
Default Re: B16 EF guys.. What air intake? (b18k1)
Don't be lazy!
The AEM CAI for the 99-00 Civic Si is well worth it.
Don't use a D series intake on it, you're only hurting optimal performance......
Old Sep 12, 2002 | 04:18 PM
Art701's Avatar
Default Re: B16 EF guys.. What air intake? (Phatwhippin_CRX)
intakes don't really matter. . .it's just piping. . .that's just my opinion, but to keep your battery, just use the one needed for your chasis. . .
[Modified by Art701, 1:19 AM 9/13/2002]
Old Sep 12, 2002 | 05:20 PM
EF-9SiR's Avatar
Default Re: B16 EF guys.. What air intake? (Art701)
i use an aem short ram for a dohc del sol
Old Sep 12, 2002 | 05:54 PM
bryant's Avatar
Default Re: B16 EF guys.. What air intake? (EF-9SiR)
Homemade Rules!!
Cost me $30, and i can have short ram or cold air and its still 3"
Old Sep 12, 2002 | 06:42 PM
Default Re: B16 EF guys.. What air intake? (89_Y_49RIP)
I meant the Optima gel based battery, it is smaller. StorminMatt runs it on his B16a he also runs an 99-00 si intake. Just an option if you don't want to relocate your battery, and want the appropriate size intake for your B16a.
Old Sep 12, 2002 | 07:40 PM
Tbone's Avatar
I run a 99 si iceman, but i found out that they actuall make a hybrid swap intake. However I'm not sure if with that one they require the relocation of the battery. You can find a pic of mine here in this post. https://honda-tech.com/zerothread?id=274373
Old Sep 12, 2002 | 08:00 PM
All Motor Rex's Avatar
Default Re: B16 EF guys.. What air intake? (Tbone)
Does the Iceman for the 99 Si have a larger diameter pipe? Is that why you chose that one instead of the one made for the CRX?
Old Sep 12, 2002 | 08:04 PM
StorminMatt's Avatar
Actually, you want to use an Odyssey battery. Not an Optima. The Optima is actually larger than the stock Group 51. Speaking of intakes, another choice is the Injen. Even the Injen intake for the D16A6 is a 3 inch piece. So it should be better than the puny 2.5 inch AEM CAI designed around the flow capacity of the D16A6. But I don;t know how it compares with the AEM CAI for the 1999-2000 SI (which is specifically tuned for the B16A).
Old Sep 12, 2002 | 08:08 PM
marty's Avatar
Default Re: B16 EF guys.. What air intake? (StorminMatt)
INJEN CAI intake for 88-91 CRX Si/EX. Fits like a glove.
Old Sep 12, 2002 | 11:04 PM
guttedEF's Avatar
I was lucky enough to find a JDM intake tube from an EF SiR. I use that with my stock airbox with a K&N drop-in. I like it alot.
Old Sep 13, 2002 | 03:19 AM
Monty's Avatar
Default Re: B16 EF guys.. What air intake? (guttedEF)
Nice!!!! Im trying to do the same. If not storminmatts set-up seems the best
Monty
Old Sep 13, 2002 | 05:28 AM
ricodemus's Avatar
Default Re: B16 EF guys.. What air intake? (Monty)
I use the 99-00 si intake with a Stinger Red top battery. I think it appears in the pic post.
Old Sep 13, 2002 | 08:13 AM
Malgerus's Avatar
Hmm. I always though that the AEM intake was supposed to be a smaller diameter than other brands; something about air velocity, can't quite remember what. Apparently the bigger tubing slows down flow or some crap like that. Is the 99-00 much bigger than the CRX one?
Old Sep 13, 2002 | 09:27 AM
SuperCivic's Avatar
Default Re: B16 EF guys.. What air intake? (MugenEF7)
guys, this is REALLY the way to go..3 inch piping and perfect fit. no 2 inch crap, no battery relocation, nuthin. this is the one.
Old Sep 13, 2002 | 11:58 AM
SiZ's Avatar
SiZ
Default Re: B16 EF guys.. What air intake? (SuperCivic)
Thanks very much for the help e'ry body.
I think I'll look in to getting an injen.
Old Sep 13, 2002 | 12:01 PM
MADEINIRAQ's Avatar
i'm using the stock airbox with k&n filter.. and using the intake tube that came with my motor.. integra xsi probably
Old Sep 13, 2002 | 02:20 PM
ViZ's Avatar
ViZ
Default Re: B16 EF guys.. What air intake? (madeiniraq)
92 teg aem CAI works good
sorry bad angle
[Modified by ViZ, 3:22 PM 9/13/2002]
