Japanese suspensions tuners converting to rear stiff setups?
Old Sep 12, 2002 | 01:13 PM
6ghatch's Avatar
Default Japanese suspensions tuners converting to rear stiff setups?
I've been looking at a couple of Japanese brand web sites and noticed something strange. The "out of the box" spring rates for the new Civic and Integra Type R's are higher rear rates!! For example the spring rates on the Buddy Club racing spec dampers for the DC2 are 12k front and 8k rear, but for the DC5 they list 10k front and 16k rear, same goes for the new CTR. I even checked Tein and they are also going with higher rear rates. Are the Japanese companies following in the "American" racers footsteps? Or are the new body styles just that much different that they needed to rethink the settings?
Old Sep 12, 2002 | 01:15 PM
yoshi234's Avatar
I shoot brides
Default Re: Japanese suspensions tuners converting to rear stiff setups? (6ghatch)
i've noticed this also, but also on cars w/ Mac strut sus
Black R's Avatar
25 Year Member
.....probably has something to do with the front macpherson strut setups.
Old Sep 12, 2002 | 01:41 PM
TypeR0207's Avatar
Default Re: Japanese suspensions tuners converting to rear stiff setups? (Black R)
That, and stiff rear helps to get rid of the incessant understeer of Honda products .... to a point, then you start roasting your rear tires as they slide around so much ....
Old Sep 12, 2002 | 02:06 PM
Spikey's Avatar
It is due to the mac struts on the new generation cars
don't get too excited
Old Sep 12, 2002 | 02:14 PM
tonyxcom's Avatar
Default Re: Japanese suspensions tuners converting to rear stiff setups? (Spikey)
The rear is a totally different suspension geometry.
If you also notice, you will see that the shocks are closer to the center of the car, meaning the LCA's have more leverage on the shock, and hence the higher spring rate to compensate.
It is still a front stiff setup.
Old Sep 12, 2002 | 02:29 PM
6ghatch's Avatar
Thought I was onto something oh well
Chris- who did not realize even the rear suspension design was also changed.
[Modified by 6ghatch, 6:46 PM 9/12/2002]
Old Sep 12, 2002 | 02:57 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
Everyone was right here. Spring on a front strut geometry is more effective (further out to the wheel) so the rate doesn't have to be as high.
I haven't looked into too many DC5R setups. But for the DC2R, even with stiffer front springs and thicker front sway bar, it doesn't mean that the front roll stiffness would be dramatically higher than the rear because of the less effective front spring rates and longer leverage of the sway bar.
realis9
Suspension & Brakes
Apr 10, 2007 07:40 PM
vinuneuro
Suspension & Brakes
12
Jun 26, 2006 08:47 AM
jt-sport
Suspension & Brakes
Dec 11, 2005 08:07 AM
jond
Apr 12, 2004 07:19 PM
ht834Crx
Mar 27, 2003 12:00 PM
