crx need a little help here throwing a o2 code
wassup fellas im a newbie to the honda forums
Anyway I have a B16A2pr3 OBD0 swap on my crx> Its throwing a cell I check the light on the ecu and it blinks once and theres a pause for 4 to 5 seconds and it blinks again. I look up the code and apparently is the 1) Primary oxygen sensor- Defective circuit or unplugged/ Defective sensor
I have two o2 sensor is there a way to wire just one o2 sensor for it to work properly. If not which is the primary oxygen sensor and where can i get one? Any help will help thanks
both sensors are needed for the obd0 b16 ecu. i would check to make sure both wires from the sensors are making it back to the appropriate spots on the ecu.
Thanxs everyone for the insight. I change both of my o2 sensor my car is runing smooth now that might have been the problem. replace ur o2 sensor and ur car will run better
EKdriverin703
May 5, 2011 07:21 AM
