Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2001 Honda Odyssey Ex crazy oil & water leak!! Help!!
Old May 22, 2010 | 03:34 PM
Rotibajan's Avatar
Default 2001 Honda Odyssey Ex crazy oil & water leak!! Help!!
I had a water leak about two months ago and the car over heated twice in one week and after having rectified the problem by flushing the radiator, changing the gaskets on the front and rear water housing, a new Honda seal on the feeder pipe that comes from the water pump and a new Honda thermostat( never use an aftermarket thermostat in a Honda engine, buy the two and compare and you will see the difference believe me).
Now my problem is I have developed an oil leak on the drivers side if the frontal head (not the rear) that after the car warms up for about 15 to 20 mins oil starts to run towards the front of the head and drips off the little lip that has the engine number (this is directly below the where the head meets the block on the drivers side).
Can anyone tell me if they have experienced this before and if there are any mechanics here, can you tell me if this is a sign of a blown head or bad head gasket? I have since then been driving the car fine for now but having to constantly add oil once a week. The car runs fine but the engine misses/stumbles just a bit but noticeably so.
I would appreciate any info that anyone can share please.
NOEL4151
May 18, 2016 07:03 PM
Flatland2D
Jul 15, 2010 12:54 PM
caminSi
Jul 27, 2006 07:52 AM
arielb1
Oct 26, 2004 10:38 PM
ECKOTYPER
Jan 28, 2004 01:17 PM
