FS/FT MISC Honda/Acura parts in Charleston,SC
I am a Honda Technician here in Charleston, SC. Not a scammer.
Everything is OBO, unless other wise noted.
Will ship smaller items.
I am paypal verified, and have tons of vouches.
My Name is Ashby Mahon formally know as p00n.
Phone number: 843-377-3733
Email: mahon643@gmail.com
Feel free to text or email with questions
I have many pics on my phone of these items. I am unable to upload pics at this time due internet restrictions here at work.
- 06 TSX 6sp Trans. NON-LSD Needs a 2nd and 3rd Gearset ( due to excessive grinding and customer kept driving it like a retard ) $400
- 2 15'' steel wheels from 2001 Civic LX ( 4x100 ) w/ 205/50/15 BFG Drag Radials. $100
- 2 DA Integra rear trailing arms WITHOUT calipers, rotors, or pads. They come with E-brake cables
- Viper 5000 Alarm System removed from my 94 Integra in perfect working order. Only thing is that the remote with the screen on it was lost a while ago, and only have the small one that has the lock and unlock feature. Make offer $$$$$
- B18B block, crank, and oil pan $200
- JDM B18C block from Hmotors. NO CRANK!!! I do have an LS crank that you could use for a small stroker setup. Have all accessories. $250
- 95 GSR Gauge Cluster no problems, removed only to install ITR cluster. $75
- Suspension Techniques REAR 21mm swaybar ( GREEN ) for 88-91 Civic/CRX, LIKE NEW. Comes with brackets that bolt up to where the tow hooks bolt to the frame, and also have spherical endlinks $125
- 94-01 Integra front brake calipers, with OEM pads about 50% life left. $50
- 94-01 Integra stock radiator, bought new a year ago. Removed to put in aluminum rad. $50
- 94-01 Integra condensor fan assembly $25
- (4) TSW 15'' rims with 205/50/15 tires with 8/32nds tread depth. They look alot like SRT-4 Neon wheels. $300.
- Y21 B16a2 Transmission from 95 DelSol VTEC, no grinds! Same gear ratios at USDM ITR trans, 4.4 final drive NO LSD. However, it does sometimes not want to go into reverse. When I get some time on my hands I will open it up and fix it. I just removed it from my car this week. AS IS $450, Fixed $600 I can also work something out with you if you have an LSD you would like to have installed, I can install it and fix the reverse for an additional cost.
- Venom 400 Module...... speaks for itself, all wiring there, in the box. $35
I am forgetting somethings, I can get pictures up asap. I am also entertaining trades of all sorts, wheels, b series parts, ect. You never know.
