B20z swap with crower 402s no power down low
Old May 21, 2010 | 09:42 PM
akurtzer57's Avatar
Default B20z swap with crower 402s no power down low
Ok first to start here is what I got. 1990 Integra B20z LS was orignally auto when swapped the car. Ran great plenty of low end power. I did a 5 spd swap at the same time I also installed block guard, arp head studs, new head with crower valvetrain, crower 402-2 buddy club cam gears. Felpro head gasket. Compression check good on all 4 cyl. It is dead down low. Car basically dies if try to take off. Unless Rev up alittle and drop it. Even when shift is dead until 3k then it runs like it should. Since then I converted to obd1 with chipped ecu. Currently on a stock tune. Timing marks Line up perfectly. Cam gears a set to 0 not adv or retarded. I have tried going both ways with them. Any input would be great.
Old May 21, 2010 | 10:07 PM
mtber's Avatar
Default Re: B20z swap with crower 402s no power down low
The solution could be as simple as needing to properly tune the ecu/vehicle.
Old May 22, 2010 | 09:50 AM
akurtzer57's Avatar
Thats what Im hoping. I can't run crome on my laptop because I run vista. So won't be able to tune till get to a buddys house to try it out.
Old May 22, 2010 | 06:25 PM
bigD's Avatar
crome works fine with vista
Old May 22, 2010 | 06:47 PM
akurtzer57's Avatar
im having troubles loading it. Mhmm Any ideas why not loading?
Old May 22, 2010 | 07:21 PM
bigD's Avatar
you have to run as admin and disable user account controls
Old May 22, 2010 | 10:09 PM
akurtzer57's Avatar
Thanks. Disabled user account controls and works fine. Tuning should get me running right.
JDM_Risa
Mar 9, 2006 09:30 PM
gac_gonejeepin
Jul 23, 2004 03:51 PM
hondacivic4g
Apr 20, 2004 12:03 PM
