Help. Overflow tank overheating.
Old May 21, 2010 | 08:30 PM
mish__'s Avatar
Default Help. Overflow tank overheating.
Everytime I drive on the freeway for about 30 minutes, my overflow tank starts to overheat, bubble, and overflow. My radiator doesn't overheat though and my cluster never shows up that my car is overheating. My hose are fine and thermostat was changed months ago. Any idea why this is happening?
Old May 21, 2010 | 09:17 PM
96DelSol's Avatar
Default Re: Help. Overflow tank overheating.
hmmm you might have air in your system. You are using rad fluid right?
Old May 21, 2010 | 09:28 PM
mish__'s Avatar
Coolant, yes. I've heard stuff from maybe I need a new radiator cap Because Its so old and the seal is gone to... Maybe my headgasket is blown again. But I replaced everything last summer and everything was a-ok and it doesn't have usual blown headgasket symptoms. But my car is revving up sllooooow.
Old May 21, 2010 | 09:31 PM
96DelSol's Avatar
I would flush the whole system and get a new cap. If you blew your head gasket you would start to get oil in your radiator.
Old May 21, 2010 | 09:36 PM
jonathan13's Avatar
check the oil for coolant first, is it boiling over into the overflow? that does sound like a headgasket especially with the sluggish rev.. did you have the head surfaced at a machine shop when you replaced the headgasket last summer?
Old May 21, 2010 | 09:47 PM
96DelSol's Avatar
X2 I would check for oil before the flush.
Old May 21, 2010 | 09:49 PM
jonathan13's Avatar
if your dipstick looks milky or it looks like a puddle in walmart parking lot inside your radiator then your in trouble
Old May 21, 2010 | 10:09 PM
mish__'s Avatar
No I didn't get it resurfaced, but after it was fixed, it held up since....' no the radiator is not overflowing to the overflow tank. It's boiling it's on water etc. The dipstick, oil etc... Is not milky. The exhaust is not blowing out smoke. My cluster is not showing up as it's overheating. Yes, my car has been revving slow. And my vtec solenoid has been leaking.
Old May 21, 2010 | 10:11 PM
jonathan13's Avatar
hmmm... you got me there.. try the radiator cap, bleed the system, and pray like hell.
ltapia707
Honda Civic (2001 - 2005)
12
Mar 19, 2013 02:57 PM
bark3rk20
23
Apr 18, 2009 09:25 PM
EJ1 guy in LBC
Sep 28, 2008 04:01 PM
bigsyke
Jun 7, 2008 02:13 PM
mickey513
Dec 20, 2004 02:22 AM
