your thoughts on the quality of this head?
Old May 21, 2010 | 03:50 PM
Spawne32's Avatar
Default your thoughts on the quality of this head?
getting ready to send the head out for port and polishing off the spare engine, just now pulling it apart, and this is what i found. Needless to say its worse then i anticipated.
any pointers on how to determine whether the internals are reusable?
Old May 21, 2010 | 04:02 PM
non-VTEC's Avatar
Default Re: your thoughts on the quality of this head?
looks like the oil changes were extended beyond "normal" intervals. but it does not matter since you will send it to the machine shop anyway. they will be able to clean all that gunk out once they hot tank it.
Old May 21, 2010 | 04:05 PM
Spawne32's Avatar
what about the marks on the cams, and relation to that and the rockers, anything to be concerned about?
Old May 21, 2010 | 06:16 PM
b00stcreep21's Avatar
Maybe you should change your oil every now and then? Just a thought. As long as they're just marks, and not scoring, you should be ok re-using them
Old May 21, 2010 | 06:29 PM
Spawne32's Avatar
if only it was from my car then that statement would be valid, unfortunately this is a spare engine i picked up that im disassembling.
projectTeG's Avatar
it looks like it was running fine, just extended oil change. the cam journals still have the oem crosshatch(thats good). the marking on the cams could just be from the engine sitting.
take the head and get it cleaned and checked, im sure it fine.
wesley_925
Mar 31, 2008 05:00 PM
weiRtech
Welding / Fabrication
17
Feb 2, 2006 07:58 AM
B18Redline
Jan 28, 2005 07:30 AM
iperez
Jan 22, 2004 03:00 PM
ForcedAir
Jul 1, 2003 08:23 PM
