Huge wiring mess! HELP
Old May 21, 2010 | 01:20 PM
Volcomcy's Avatar
Default Huge wiring mess! HELP
I have an 88 Crx SI. It had a cut wiring harness under the dash where the ECU goes.
so I replaced it with a 91 SI wiring harness. The engine harness is an 88 HF. When I try to start the car i hear a click from the main relay but nothing happens other than the high beam on the driver side head light turns on....
I connect a wire to the starter and It doesnt get spark. anyone know if pinout is different from the 2 wiring harnesses. THANKS!
Old May 21, 2010 | 02:00 PM
jlicrx's Avatar
Default Re: Huge wiring mess! HELP
HF and Si harnesses are not the same - you could re-pin the connectors and do some modifications and make it work:
Ahknodd
May 27, 2008 06:16 PM
Vagabund07
Sep 14, 2006 07:32 PM
red civic standard
Sep 13, 2006 09:09 AM
smash fascism
Mar 5, 2006 08:32 PM
