92 VX- D15z1 / D16z6 SWAP
Old May 21, 2010 | 05:10 AM
Duhul's Avatar
Default 92 VX- D15z1 / D16z6 SWAP
Does anyone know a of a good write up for a d15z1 to d16z6 swap?
I think my vx's engine is crapping out and I want to start a swap.
Thanks for the help.
Old May 21, 2010 | 10:04 AM
SOHConthis's Avatar
Default Re: 92 VX- D15z1 / D16z6 SWAP
nothin really changes or you'll have no problems i did it on mine its a 92 vx and iv had 2 z6 swaps in it already ..but the cel will stay on cuz of the cesor beside the vtec selenoid .
Old May 22, 2010 | 08:20 PM
f3rcho's Avatar
hey the man i did my swap today but hey the car wont start not even crank, what do u think can be the problem?
and hey there is one more thing when i used the z6 wire harness there is a plug socket missing on the left tower, should i used the vx harness insted could be that the reason?
Old May 22, 2010 | 09:52 PM
EFPhilly's Avatar
It is because the vx came with 4 plugs and regular harnesses came with 3. Mine had the same problem. Switch the engine harness to the vx and it will start...orr will if the motor is fine.
The good thing about the VX harness is that it came wired for VTEC. The only thing that makes it as pain is wiriing the 5 wire o2 to a 4 wire. Not that hard to do...but hard to make it look stock (becuase of the one, i believe black wire not in the plug)
Old May 23, 2010 | 04:07 AM
f3rcho's Avatar
oh ok im going o try this and see what the results and by the way how do u do the O2 rewire???
i dont get it .............
thanks
Old Jun 12, 2010 | 07:29 PM
f3rcho's Avatar
hey was up
i did used the vx harness and it did start, but hey i dont understand how to get rid of the check engine light, and what i saw on the socket of the O2 sensor it has more that 5 wires and would like to know if anyone know how to rewire the O2 sensor to a 4 wire one
Old Jun 15, 2010 | 04:52 PM
reloadmylove's Avatar
Hello, Don't know if anyone is still hanging around this thread, but I'm really hoping so...I just swapped a d16z6 into my VX, kept all my VX harnesses and wiring, everything is still stock VX except for the complete motor itself, and the intake manifold. Also running a p28 ECU. Car will not fire...turns over but wont start...I've heard things about rewiring the O2...I havent done this yet, will this keep it from running? I'm not hearing my fuel pump kick on, and I have no spark...however I have fuel coming through my injectors and 12 volts to my distributor. Any help please?
Old Jun 15, 2010 | 08:20 PM
cvxd's Avatar
there is an archived thread on this to change the pins on the shock tower. VX also has a block box on the firewall- a plug goes there & your P07 ecu is looking for that. Does the EX or z6 have an egr? been a while since i had one in my vx. I did the opposite and went from d15b vtec(ex essentially) back to stock vx. Another way is to just get a Z6/EX wire harness-no splicing.
Do you wanna sell any of the VX stuff? like ecu, IM, TB & injectors...?
Old Jun 20, 2010 | 11:43 AM
EFPhilly's Avatar
There is so many write ups on this.
Old Jun 20, 2010 | 02:30 PM
chrono404's Avatar
Make sure the Small Wire is connected to the starter, Also make sure the engine ground is connected, It will be on the rear water pipe next to the thermastat. I have had these issues stopping my fresh engine swaps before.
Old Jun 20, 2010 | 03:53 PM
EFPhilly's Avatar
the O2 will not make the can not start. Only two things make the car fire....fuel and ignition. I would check the sensors vis a 9 volt battery and a multimeter then you will see what sensors (prolly dizzy) arent working. Ground each spark plug to verify spark. But really...do we need another no start thread....
GO TO THE FAQS.
I PM'ed you the 4 wire o2 wires.
Old Oct 8, 2010 | 06:00 PM
sanchez831's Avatar
i have the same problem i bought a 95 civic vx. but it has a d16z6 when it was supposed to have the 1.5 v tec can somebody tell me how to convert the 5wire O2 sensor to a 4 wire one. thanks
Old Oct 8, 2010 | 06:54 PM
94EG8's Avatar
Seagull Management
VX O2 sensor fix:
JST1CAM
Jun 7, 2006 12:18 PM
kam1kaz3
Jun 24, 2005 05:24 PM
pdcivic
11
Aug 3, 2003 06:56 PM
jas0n
Nov 15, 2002 04:17 PM
