i had no idea wats wrong wit my crx....
it wont start the engine....
it crank but wont start...
give me a clue..i charge my battery full
still does the same...checking spark plugs its still
good but oil is in 1st spark plug wire.....
i guess its a spark plug...also maybe the starter...
starter seems old for me....what do you think honda?
lets think just a little about this, if it cranks over the starter and battery are both fine, cant say for sure on the plug wires but probably not, something else is wrong
if it was the starter it wouldn't crank at all. you have to make sure you're getting spark and fuel so check your spark plugs, spark plug wires, distributor, etc. if you have spark make sure you are getting fuel so check you're fuel filter, fuel pump, injectors, etc.
slash00R
Jul 30, 2002 03:54 PM
