7k rev limiter w/ b16
Old Sep 12, 2002 | 11:17 AM
johnzm's Avatar
Default 7k rev limiter w/ b16
i got a PWO ECU, and a b16 wired up. i have been letting it idle in my garage, i revved it to 8 and it bounced off of 7k. can this be true or is it a guage discrepancy or what?> its in a 90 civic SI
Old Sep 12, 2002 | 11:30 AM
realhondaperformence's Avatar
Default Re: 7k rev limiter w/ b16 (johnzm)
Are you sure you have a vtec ecu? thats what revlimiters are on Ls's.
Old Sep 12, 2002 | 11:36 AM
johnzm's Avatar
Default Re: 7k rev limiter w/ b16 (realhondaperformence)
its a PWO. i was under the assumption that a PWO was an SIR ecu fomr a 88-91 civic/crx SIR
Old Sep 12, 2002 | 11:43 AM
johnzm's Avatar
ugh it seems like its at 7200
ANYONE with a PWO ecu- does it redline there? does it have a rev limiter there when its cold?!
Old Sep 12, 2002 | 11:50 AM
ricodemus's Avatar
yes, rev limiter. you may not have the oil pressure or one of the things needed for the ecu to allow vtec. let the car warm up, check your oil.
Redline is 8k, fuel cut off is 8200 in a normal, warmed-up engine.
[Modified by ricodemus, 3:50 PM 9/12/2002]
Mr Furball's Avatar
if you have the stock guages in the car, the RPM guage is slower then it should be.
If you go out and buy an aftermarket RPM guage and hook it up the guage will go to 8000. I have a crx with a B16 and the Rpm go to 7600 but when I hooked up the aftermarket autometer it went to 8100.
Good luck.
Old Sep 12, 2002 | 11:52 AM
johnzm's Avatar
Default Re: 7k rev limiter w/ b16 (FURBALL B-16)
aight man, thnx for the response guys. are any of u runnig the PWO ECU?
Old Sep 12, 2002 | 11:53 AM
SuperCivic's Avatar
isn't there an auto ecu that doesn't rev as high? maybe you got an auto instead of manual.
Old Sep 12, 2002 | 11:55 AM
johnzm's Avatar
Default Re: 7k rev limiter w/ b16 (SuperCivic)
i was thinking that too, i forget how to tell tho.
i am more thiking its becsue its cold, but i need someone else with a PWO ECU to confirm that a cold start map has a lower rev limit..
Old Sep 12, 2002 | 12:01 PM
NikoZai's Avatar
The SiR ECU is "PR3" and VTEC will not kick in at a standstill, 3 things effect it:
1. Tempature
2. RPM/Oil pressure
3. SPEED it wont kick in until 15mph
it gets your speed off your speedometer, so if your speeedometer doesnt work, neither does your VTEC, it is cable drven, the only thing sensing the speed is the gauge cluster.
Old Sep 12, 2002 | 12:02 PM
Mr Furball's Avatar
Well first off I hope that no one is reving the motor to 7-8000 when the motor is cold because this will harm the motor because it is not at operating temp.
Old Sep 12, 2002 | 12:03 PM
johnzm's Avatar
Default Re: 7k rev limiter w/ b16 (NikoZai)
1. Tempature
2. RPM/Oil pressure
i know VTEC isint supposed to kick in , but i shuld stil be able to rev it at a standstill
Old Sep 12, 2002 | 12:05 PM
johnzm's Avatar
i know this, but im sure im not the first to do it and i wont be the last. and i dont make it a habit of doing every day, i just got like 10 cups of gas int he tank and it cannot move until i get a half shaft.
Old Sep 12, 2002 | 01:44 PM
maskednegator's Avatar
make sure you don't have the engine temp sensor and vtec oil pressure plugs switched. if you're getting a code 6 then the engine will keep the cold start rev limit of 7200.
Old Sep 12, 2002 | 02:05 PM
15psi of fun's Avatar
Default Re: 7k rev limiter w/ b16 (maskednegator)
i have a 91 civic si with a b16. first my tach is dame acurate. i have the PR3 ECU and when it's coold it rev to 7K and wormed up it rev to 8200. I have atlest two friends that have had that problem and it was becase thay had auto ECU after geting them rechip the problem was fixed. Try this site http://jdmhondaparts.com/frameset-ecu.htm
good luck
Old Sep 12, 2002 | 03:10 PM
johnzm's Avatar
Default Re: 7k rev limiter w/ b16 (EFrollingout)
good luck
THIS answers my quesiton. it does then have a cold rev limiter ~7k. thnx for the responses guys. as always ur great help
Old Sep 12, 2002 | 03:29 PM
......'s Avatar
you definitely have an automatic ECU. The same thing happened to me and I took it back and traded it for a manual.
Old Sep 12, 2002 | 04:02 PM
xtrafastcivic's Avatar
Default Re: 7k rev limiter w/ b16 (......)
why do you want to rev it to 8k from a standstill???
demastus18
Jul 28, 2014 02:27 PM
scooterbuilteh2
15
Oct 1, 2009 08:44 AM
crxh22project
22
Feb 14, 2005 05:19 PM
teler86
14
Nov 27, 2004 01:26 PM
95cx
Jan 15, 2003 07:53 PM
