Honda S2000 Honda S2000
maintenance required sign....
Old May 20, 2010 | 12:29 AM
fohc_v-tec's Avatar
Default maintenance required sign....
Hey my maintenance required sign was blinking for about 1 minute and it shut off is there something i should check for my car when it does that or let it go??.... my car 2003 s2000 milage is 92928 and i changed my at 90000 miles......
thanks
Old May 20, 2010 | 10:55 AM
Zaakro's Avatar
Default Re: maintenance required sign....
its only for changing your oil. you need to reset it after you change it
Old May 21, 2010 | 09:00 AM
White Smoke's Avatar
i my honda
Global Mod
Yes, it's letting you know that you are approaching the oil change interval. Once you get there the light will come on, and stay on. For the AP1's I think it come on every 5k miles or something along those lines. It is NOT every 3k...
To reset:
Insert key in, but do not turn it on
Hold trip button on gauge cluster
Turn the key to full "ON" position
Continue to hold trip button (about 20 seconds) until the maintenance light goes out.
If you have other questions in the future, always be sure to try a search first! Allot of this info has been cover here on honda-tech in the past.
DohctorVtec
Honda S2000
Nov 20, 2009 03:54 AM
kloscivicsi
Honda S2000
Mar 30, 2007 05:05 PM
nudvl
Honda S2000
Oct 9, 2005 03:48 AM
jdm_eg
Jan 4, 2005 12:56 PM
Acc99ord
Mar 31, 2004 02:33 AM
