Valve adjustment
Old Sep 12, 2002 | 10:48 AM
grngsr01's Avatar
Default Valve adjustment
I have 25k on a 01 gsr. I was wondering if i would benifit by adjusting the valves? Will there be any difference in power? If i do decide to do it, is it a hard task and do i need that special wrench?
Old Sep 12, 2002 | 10:52 AM
DR3AM's Avatar
Default Re: Valve adjustment (grngsr01)
Depending on how hard you drive your car, I would do the valve adjustment every 15K miles. This gets rid of the valve tap and also helps to make to your engine run a lot smoother.
I've never tried to adjust my valves myself because I usually have it done when I get my car serviced
[Modified by Gizzzer98, 7:53 PM 9/12/2002]
Old Sep 12, 2002 | 10:57 AM
Trigun's Avatar
if you drive your car hard, i would do a valve adjustment.
it's not that hard. you need a feeler guage and a valve adjustment tool and it takes anywhere from 1-2 hours your first time.
Old Sep 12, 2002 | 11:31 AM
grngsr01's Avatar
Default Re: Valve adjustment (Trigun)
what do u consider driving hard. Taking is to the red once and a while, shifting at 6k?
Old Sep 13, 2002 | 11:46 PM
grngsr01's Avatar
ttt
Old Sep 14, 2002 | 02:37 AM
Westrock2000's Avatar
I can do those puppys now in about 20 minutes, however the damn things never want to stop ticking, i've tightened em up too like 0.004 IN and 0.006 EX and they still tap...
Old Sep 14, 2002 | 05:56 AM
Tweakmeister's Avatar
Default Re: Valve adjustment (Westrock2000)
...could be your injectors ticking.
NEDan
Honda Fit
Aug 4, 2017 06:30 AM
pr3lude1992
Apr 1, 2009 05:33 AM
kornerk12
Dec 18, 2005 03:27 PM
vulgar_si
Nov 18, 2004 05:31 AM
96tegsr
Jun 20, 2001 03:46 AM
