!!!EJ1,K20z3 and K20a2 Part-out and MOORRREE!!!
that's kind of high bro this is a rebuilt motor with quality parts and your getting everything to put in your eg.......engine,tranny,wiring harness,mounts, axels, linkage, chipped p28, a/c bracket from crv... everything!!! thats worth a lot more than 2300 and that's not including the aftermarket parts it has.
^^ yeah bro full swap, you will need nothing to put this in your car and have it run except for gas and oil.... 500 on top? we can work something out to where we are both happy
what i have is..
2008 k20z3 longblock approx. 15xxx miles
2004 k20a2 tranmission approx 15xxx miles
Hasport EGK1 mounts
RBC intake manifold (brand new)
2004 uncut engine and charge harness'
Rcrew swap header (used)
AEM fuel set up (regulator, rail and an fiitted lines)
BuddyClub RSX short shifter box
you need to get injectors, some sort of EMS, shifter cables, alternator, starter and some axels.
Hasport EGK1 mounts
in the parts i have listed i have over 4000 dollars invested......what other parts do you have to include the 500 is a little low......
ok how much time do I have to get the rest of the parts I need to swap this in my car also need the conversion harness and also the sifter plate kit
i can make the conversion harness for you and you dont really need the shifter plate unless you want the interior to have a stock look with the plastic's. take as much time as you need......
