i need help...MY CAR WONT START.
Old May 19, 2010 | 08:55 PM
civic-vitec's Avatar
Icon6 i need help...MY CAR WONT START.
hi
i was riding my pretty civic back home and suddenly from out of now where the car poped out it was like exhaust problem then the car stoped and i tried to turn it on over and over my lady wont start
evry time i started it there is pop sound and it's dies immediatly
so,
if some one can help me out here i want my car to run again.
maybe it's an electrical issue.
engine jdm h22a /ecu p13
Old May 19, 2010 | 09:13 PM
90sedan's Avatar
Default Re: i need help...MY CAR WONT START.
Sounds like the distributor rotor came loose. The engine probably isn't getting spark, which caused it to die and not restart. The popping noise is normally caused by a loose rotor. Remove the distributor cap and inspect the rotor.
If the rotor came loose, you can use some blue loctite to help secure the bolt better.
Old May 20, 2010 | 08:32 PM
thank you sir
i replaced the distributor and the car became alive again.
SupremexGSRx
Dec 15, 2007 06:03 PM
az90civic
Sep 1, 2007 05:51 PM
John F
Oct 10, 2005 03:30 AM
LsVtecDA
Mar 30, 2003 05:17 PM
chirp2hrd
Sep 1, 2002 03:26 PM
