EDM 96-00 clock question
Old May 19, 2010 | 06:41 PM
b18c inside's Avatar
Default EDM 96-00 clock question
I received the digital clock today. What trim piece do i need to make it fit correctly? Part number?? I have and plan on keeping my CD player in my car. But what is the part number for the trim piece around the clock? Or is that the whole entire climate control bezel? Thanks.
Uploaded with ImageShack.us
Old May 19, 2010 | 06:45 PM
Ef8crxsi4u2nv's Avatar
Default Re: EDM 96-00 clock question
That Sir is indeed the climate control bezel
Old May 19, 2010 | 06:47 PM
b18b1turbo's Avatar
You have to take your whole entire climate control bezel off and there are two screw that you have to screw in...
Old May 19, 2010 | 06:55 PM
Thanks!! Very helpful. Points me in the right direction. Now...how hard are they to find?
Thanks!!
Old May 19, 2010 | 07:00 PM
-Gambit-'s Avatar
sir climate control not needed. you can used the usdm and just take off the climate control trim and put the clock in
Old May 19, 2010 | 07:26 PM
b18b1turbo's Avatar
i did it last week...pop off the hazard botton and the defrost bottom theres screws behind it...remove the bottom piece that has the power outlet...there should be 4 screw down there... i remove the glove box to get to the 2 screw holding it in then do the same to the other side too...think thats all...then put your clock in and screw it in,it should have holes for you to screw it in...
Old May 19, 2010 | 07:34 PM
i'm familiar on how to remove the bezel. I did it to install the amber climate controls. But the clock doesn't just fall in to place where the pocket is at. The picture is of an SIR climate control bezel. If you did this install, please show me some pics. Do you have the SiR climate control bezel?
Old May 19, 2010 | 07:39 PM
b18b1turbo's Avatar
don't have a SiR climate control,have a USDM...sorry no pictures... isnt there two holes behind your climate control bezel?
Old May 19, 2010 | 07:52 PM
So what you are saying is your install looks just like the picture? I just don't see how it can.
Old May 19, 2010 | 07:55 PM
b18b1turbo's Avatar
yes it does...the clock goes behind the bezel
Old May 19, 2010 | 08:01 PM
I'm aware of that from the pic i posted. I'm also aware of the 2 screws. They hold the pocket in place also. Do you have the SiR climate control bezel? Did you cut out your pocket on the bezel to make your clock fit?
Old May 19, 2010 | 08:07 PM
b18b1turbo's Avatar
nope didnt have to cut anything. everything fit perfectly. again i have a USDM climate control.
Old May 19, 2010 | 08:10 PM
Jdmglenn's Avatar
1. Take out climate control
2. Remove stereo
3. Take out the pocket that is in place now, it pops out
4. The clock will screw in with honda interior screws
5. Wire the pigtail to the deck wire harness, for 12v, Ign. power, and ground
6. Reinstall and enjoy your clock
Old May 19, 2010 | 08:11 PM
2. Remove stereo
hahaha...thanks.
Old May 20, 2010 | 01:40 PM
Thanks man! U are right on! Kind of an optical illusion.
b2vgreendc
Mar 3, 2014 10:37 AM
Hondatypr636
Dec 28, 2008 03:30 PM
Scrappy_jm
May 8, 2008 02:28 PM
1992HB
Feb 11, 2006 05:34 PM
