D16z6 . . . No compression
Old May 19, 2010 | 06:21 PM
trevdawg's Avatar
Default D16z6 . . . No compression
I tried to search this but did not come up with much.
I bought a 95 civic from my friend for cheap and he said that he thinks it needs a new timing belt. So i buy it and then do a compression test . . . . . . no good
90. . . 0 . . 0 . . 0
is what came up, so we didn't even try to do it again cause it sounded so bad.
So we double check the timing and the timing belt and it was all good but still nothing.
We are gunna do a wet test tomorrow but i know it ain't going to be good. When i try to start the car it sounds as if the cylinders are dry and it is just scratching. . . its horrible
any info or ideas?
Old May 19, 2010 | 06:31 PM
D16SiHatch's Avatar
Default Re: D16z6 . . . No compression
engine sounds pretty toast to me
did this friend mention what happenened to leave it in its current state? if you're replacing the timing belt that would lead me to believe it probably snapped. and if that happened then the engine is definitely fubared. they are interference type and when the belt snaps the pistons make contact with the valves. sometimes you get lucky and the belt breaks at a point where the valves are all high enough that no damage is done.. but you've already done the compression test and determined that it's all kinds of muffed up.
Old May 20, 2010 | 08:15 AM
trevdawg's Avatar
ya my friend said he drove home from school, then the next morning when he tried to start the car it wouldnt start, so i dunno i got screwed, the belt wasnt even snapped
Old May 20, 2010 | 10:52 AM
StraightSixX2's Avatar
Pull the head and check the valves. If the timing belt slipped some of your valves could be toast... Does it sound like the valves are clacking?
Old May 20, 2010 | 10:58 AM
trevdawg's Avatar
No it doesn't sound like they are clacking, but i'm gunna take off the head today/ tomorrow and see how it goes from there.
Old May 31, 2010 | 05:09 PM
trevdawg's Avatar
Took the head off and . . . . the head gasket is fine, the valves visually look to be good too. But i might bring it in to get leak tested. The tops of the pistons were fine, so the valves have not been hitting the pistons.
I don't know what to do now.
Old May 31, 2010 | 05:44 PM
cvcrcr99's Avatar
Not any more at least! Make sure you get a new one.
MyWhiteEJ6
12
Nov 10, 2013 06:38 PM
sd619jef9
18
Aug 25, 2012 10:35 AM
accord2civic2prelude
Jan 22, 2012 03:17 PM
junior_tm
Jun 1, 2010 07:57 PM
carr
Nov 22, 2006 07:41 AM
