1990 crx ef8 build
Old May 19, 2010 | 06:04 PM
5efheturbo's Avatar
Default 1990 crx ef8 build
ok so i dont have a honda but one of my buddies do and so as ive had some turbo experience i guess he thought i could help with his build.
what hes wanting is 300hp reliably and he wants it to be n/a and i know this can be done but price wise and reliablity wise it would be fairly expensive so i told him going boosted would probabbly be cheaper in the long run..
what would you guys recomend to acheive this goal??? I.E. different motor swaps both na and boosted and the drawbacks and cost
Old May 19, 2010 | 06:06 PM
Staypuff578's Avatar
Default Re: 1990 crx ef8 build
Dude, this **** is covered SO much on this site and every honda site out there. Please search around a bit.
Old May 19, 2010 | 06:22 PM
D16SiHatch's Avatar
stock a d-series will not see 300 without exploding. you'd have to build it. your other option is to swap in an ls (cheapest b-series engine) and boost that. they can handle 300whp stock just fine.
Old May 19, 2010 | 09:07 PM
5efheturbo's Avatar
hey thanks for the help....oh wait I mean suck a dick...
that post was of absolutely no help
now to D16SiHatch thanks for the reply..
now what exactly is a "LS" ive heard many times but I dont know what engine that is.
Im guessing if i remember that means it dosent have vtec right?? and also would that mean a b16?
Old May 19, 2010 | 09:48 PM
MarsEf9's Avatar
What he was trying to say is, do some research. Theres so many people asking what engine would best for x amount of horsepower and be cheapest.
But yes LS is a b18a1 and b18b1 They are non-vtec, boosted they can handle 300 whp safely, and reliably on a fresh engine, with a good tune. But if you boost something with over 120k you might run into problems, gotta make sure its fresh, Does NOT burn oil at all. They are also pretty cheap, 250-400 bucks.
Hope this helps.
Old May 20, 2010 | 08:03 AM
gator88's Avatar
d16a6, good rods, good pistons, nice cam and fresh bearings and seals and bolt on a go-autoworks kit. Easily 300 and reliable if someone knows how to tune it
Old May 20, 2010 | 04:33 PM
5efheturbo's Avatar
ok thanks for the replys..so would a b18 require custom engine mounts or is it a drop in swap...also what about wiring/ecu's
Old May 20, 2010 | 06:19 PM
KillerHippy's Avatar
It would be a basic B series swap. So you need B series mounts, axles, linkage, wiring...
Old May 20, 2010 | 06:36 PM
ERKK's Avatar
Old May 20, 2010 | 08:21 PM
D16SiHatch's Avatar
it requires quite a bit actually
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
alaska street racer
Apr 25, 2009 10:31 AM
sicrx69
Aug 6, 2007 08:27 PM
99civicsiowner
Aug 30, 2006 04:55 PM
Blitzeclipse
34
Dec 18, 2005 11:41 PM
hanseljohn
Sep 2, 2005 12:35 PM
