cel light help?
i was checking my cel light to see what codes i would get and theres a problem. when i put the paper clip onto the plug and turn the ignition my light goes off and doesnt come back its not reading my code. do you guys think it has something to do with my ecu?
Ive sortof been having the same problem. But i just make sure that the paper clip is fully inserted into the connector and it seems to work just fine. I would imagine that if you check the above and it still isnt working, there is a short somewhere in that circuit, or the ecu terminals are bad.
But thats just my guess, i dont know for sure. I would just check to make sure that the paper clip or wire is making good contact.
lgragera
Aug 6, 2005 05:15 PM
