horn in my da is not workin
so my horn worked with the factory wheel but then i went to an ebay wheel and the hub was shitty so i thought that was my problem now i switched to a crx si wheel and am experenceing the same prob i looked at my fse pannel and cant figure witch is for the horn anybody know
do you have the contact ring? because the stock wheel has it, and since you switched it you probably cut the wire
on a da its the green red wire
there doesent seem to be any cut wires i took the wheel all apart and the column nada did find a gap between the si wheel and the teg column added a spacer still nothin
ok well you need the "ring" that came on the factory wheel it looks like 2 flat circles that touch but still rotate to complete the connection
it sits inside the factory wheel
