FS in NJ 1993 Honda Del Sol, auto, 211,xxx mi, newer engine, well maintained
Old May 19, 2010 | 09:06 AM
tifosi's Avatar
Default FS in NJ 1993 Honda Del Sol, auto, 211,xxx mi, newer engine, well maintained
For Sale 1993 Honda Del Sol, auto, 1.5L SOHC, 211XXXmi on body, newer 1.5L stock replacement engine. Runs good with minimal rust on rear fender wells. Current owner is a Honda mechanic and has carefully maintained the vehicle. Body is in good shape with a dent on the drivers side quarter panel in front of the wheel (may be able to see in photos). As with any Del Sol of this era, the window/ targa top seals have begun to leak. Below is a shortened list of some of the things have been replaced or maintained.
190,120 90,000 mile service, replaced rear brakes & cut drums
199,418 Replaced “B” pipe & muffler (generic), left axle & seal
203,049 Oil & filter change, replaced front brakes & cut rotors
206,873 Replaced timing belt & water pump, replaced both inner door handles, right inner & outer tie rods, both power steering rack boots, left outer tie rod boot, front lower ball joints boots, center console bulb, D4 light bulb, brake master cylinder & trailing arm bushings, 4 wheel alignment.
Please email with any further questions. Email: rfhagy@yahoo.com
Asking $2250 OBO
Jdibs77
Feb 28, 2013 11:51 AM
trphillips
Oct 28, 2009 09:37 PM
ahloung
12
Mar 5, 2006 06:03 AM
