What's a good timing belt kit for 00 accord v6 ex?
Nah I'm just a cheapo is all. So looking at the link, is that everything that is needed? Is there other stuff that I should get?
I'm having my dad's friend do this, and all he said was go get a timing belt kit and water pump. So i'm not really sure here.
What about the stuff at autozone and napa? Those aren't good?
Those are the primary parts you want to change out with the timing belt.
It's your car, personally I wouldn't be trusting my engine to Autozone or Napa parts (which probably aren't even that much cheaper)
What about this?
http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories
New Water Pump
New Timing Belt (OEM Continental)
New Timing belt tensioner
New Camshaft seals (two)
Front Crankshaft seal
It says all the parts of OEM or Genuine Honda Parts or is that just a trick for non mechanics like me?
I don't know much about cars, and since I'm having my dads friend do my car, if he replaces the poewr steering belt and compressor belt, with that first link you sent me, how long will that take or is that something that is like right next to water pump and timing belt?
New Water Pump
All parts are either Genuine Honda/ACURA, or OEA, OEM (made by the manufacturer that Honda uses ie.. Bando, Koyo, GMB, NPW, ASCO, NIPPON)
Sounds like you get a random brand assortment.
The camshaft and crankshaft seals were the other items I was thinking about.
You have to remove/loosen the other belts while you do the timing belt to get the covers off (at least for the 4cyl) I assume it is similar for the V6.
Austin Kye
Mar 27, 2018 04:41 PM
62maxx
Oct 27, 2006 03:30 PM
