cel light gone ! another little prob
whats up guys i had a couple cel lights
earlier and they been solved
but now i shut off the car for like 30 minutes came back and it wouldnt start
i tried jumper cables and nothing i took the battery to autozone and they said it was good so what do you guys think it is maybe a fuse !!
since you had the battery tested i assume you mean it isn't even cranking correct?
check to see if the spade connector on the trigger wire is connected snugly to the starter. then have someone hold the key in crank and see if there is voltage at that terminal. if there is, starter solenoid is stuck, replace. if no voltage, then your ignition switch is likely the culprit.
tried to start again lights and everything worked then when i turned the key a little click and nothing died again !! i checked to battery terminals the possitive one looks pretty beat up so im replacing both later hopefully that solves the problem what fuses should i look for
Blakesgst
14
Nov 12, 2013 04:10 PM
MonkeyMagic
Apr 30, 2005 03:08 PM
