new style 20 wire fjo injector driver turbo
Old May 18, 2010 | 07:33 PM
seanc520's Avatar
Default new style 20 wire fjo injector driver turbo
Basically the car is turning over fine and has spark but it seems my injectors are not firing. This diagram below is how i ive it hooked up. Am i right?
Old May 19, 2010 | 07:21 PM
seanc520's Avatar
Default Re: new style 20 wire fjo injector driver turbo
bump
Old May 21, 2010 | 09:25 AM
DaveF's Avatar
how did you wire the injector signal wires at the ecu, and how did you wire the injector signal wires at the injector ?
Old May 21, 2010 | 06:50 PM
seanc520's Avatar
cut them in half at the ecu and i wired them from the ecu to the input - side and from the output side of the harness to the other cut side
Old May 22, 2010 | 03:55 PM
DaveF's Avatar
obviously/....
did you double check to make sure you didnt get any of the injector wires mixed up by mistake ?
Old May 22, 2010 | 10:28 PM
HiProfile's Avatar
If I'm reading your pic right, you connected all of the 2nd set of wires, A-K? If I'm correct, they give you the option to use a possitive signal OR a negative signal. Honda ecu's use a negative signal, meaning the 2nd set of A-D (+ input) won't be connected. Some cars would use that a possitive signal, like a megasquirt ECU's signal output, when they have no injector driver inside the ecu.
The yellow/black wires at the deadend connector are always getting +12V when the main relay is on. They don't have to be connected to anything, just sealed with tape. They'll be like an extension cord hooked up to the wall but not to any tool/appliance.
Also make sure you disable the injector check if you're using something like Crome, Neptune, etc. W/o the injectors wired like normal, it will sense they are gone or all broken.
Old May 23, 2010 | 01:47 AM
seanc520's Avatar
this makes since im gonna try it thanks alot for the help!
salemned
Sep 7, 2017 12:13 PM
89ED
Jan 20, 2017 05:37 PM
Nt03hamlin
Classic Hondas
Mar 22, 2011 06:17 PM
cslegacy
Feb 28, 2009 03:56 PM
ivanson
25
Nov 15, 2005 09:04 PM
