wanna do a f23a1 all motor build!
Old May 18, 2010 | 07:19 PM
1cln_eg9's Avatar
Default wanna do a f23a1 all motor build!
hey whats up guys im thinking bout doing a slight f23a1 all motor build...still lookin to keep it a daily driver just want a little more power out my motor and its time for a rebuild anyways so i figure i do it now im lookin to get 200-250 whp out of it so im wondering.....
1.is it possible?
2.what compression should i stay around?
3.can i retrofit other pistons (h22/h23) in to raise compression?
4.do i need major head porting?
5.is it even worth spending the money?
6.do any of u guys have any advice?
Old May 19, 2010 | 09:40 AM
1cln_eg9's Avatar
Default Re: wanna do a f23a1 all motor build!
what quarter mile time should be expected?
Old May 19, 2010 | 11:15 AM
1cln_eg9's Avatar
im not lookin for a 9 second bracket.....more like 13s!
Old May 19, 2010 | 11:32 AM
Slo-mo's Avatar
Originally Posted by PirateMcFred
Ditch the F23A head and replace it with an F22A with a good valve job at a minimum.
F22A FTW.
Thats what I would do and load it up with a bunch of Bisi parts. BTW what chassis is this in??
Old May 19, 2010 | 11:39 AM
1cln_eg9's Avatar
cg5 98 accord lx probably make a blueprint of all the weight that ima cut out!
Old May 19, 2010 | 06:27 PM
Professor15's Avatar
Slow. If you want to drag race save all your money and invest in a RWD platform. There's a reason there are no dedicated FWD racing chassis out there.
LOL wow...please dont step foot in the drag-racing section than...
Old May 19, 2010 | 07:56 PM
jack sparrow's Avatar
built an f23a7 for my brother, just for kicks. dc5r pistons. stock rods. balance shaft delete. s2000 crank damper. cleaned the head and laped the valves back in. AEM cam gear. vented the vc and ported the intake man. no EGR. calculator says 11.7:1.
then thru it in a 94 4dr accord in front of an auto trans.. lol. some ebay header that i cut down and made fit snug. full 2.5 back. no cat. runs best on 110 but we retard the timing and it runs on 93 daily.
need to swap to 5sp. cant tune an auto ecu and there is alot left in there. but hey, its fun. not trying to be fast. building an f22 for boost now..
so yea.. its possible.
if you think its possible... just build it.. the least you will get is an answer.
Old May 19, 2010 | 08:14 PM
2fast4u831's Avatar
I'm really 2slow
1.is it possible?
1. it is possible.
2.stay around 12:1 to run pump gas.
3. you can use the rsx-s pistons. compression will be ~12.3:1 with the f23 head.
4. Use another head. f22a or h22.
5.It's not an investment, it's a hobby.
6.f23 with rsx-s pistons, h22 head, decent header and you should be ~230whp.
Old May 20, 2010 | 06:08 AM
1cln_eg9's Avatar
Originally Posted by 2fast4u831
1. it is possible.
damn i didnt kno u can use the rsx-s pistons....is it the same bore? can i use the stock f23 rods? has anyone did that before?
Old May 20, 2010 | 06:51 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
if you dont know whats going on dont try building an engine. first start reading and see what you need.
Old May 20, 2010 | 06:53 AM
1cln_eg9's Avatar
shoot some links my way! only poular site i seen in the f series platform is BISIMOTO!
Old May 20, 2010 | 10:58 AM
1cln_eg9's Avatar
did anyone on here do k20 pistons in a f23 block?
Old May 20, 2010 | 11:39 AM
noboostedEGo's Avatar
you seriously haven't even tried searching yourself yet...
go to search
click advanced search
select thread titles only instead of posts
type in "f23" how simple!!! you don't even have to use quotation marks! wow.
where you select the forum you want it to search, try selecting "All Motor" makes perfect sense hey?! (if you were lookin to do a turbo setup, maybe try selecting "Forced Induction"...you can even shift click and select both! holy ****)
you're doin great i know this is hard and extremely counter-intuitive...
NOW, click the final search now button at the bottom.
VOILA!!!! hordes of information! i swear it's magic
good day
Old May 20, 2010 | 11:48 AM
1cln_eg9's Avatar
go to search
good day
doing a search but some links would help now go back in ur corner u troll! mind ur business u wouldnt kno what the hell u talkin bout anyways even if u was to supply info....awful mad over there....didnt get laid? blue ball bastard!
Old May 20, 2010 | 03:59 PM
What's funny is that i followed those exact directions (the ones i wrote out so kindly fo you) and was provided with plenty of links...in fact there were even build threads mentioning k-series pistons...IN THE TITLE!!!!
and i taught you how to search...so you should be doubly thankful.
You're welcome, and you're welcome again.
Old May 21, 2010 | 08:00 AM
BudIce's Avatar
F22A head flows very well. I can wait to get my 90mm f22 in my car later this year.
killaxkev92288
17
Dec 24, 2010 11:03 PM
l3adunkadunk
Jan 21, 2009 01:25 PM
curioso
Nov 26, 2007 06:00 AM
Green JDM-R
Mar 8, 2007 06:18 AM
Desperado
May 12, 2003 01:35 PM
