new car ls vtec question
so i finally got rid of my jetta vr6 and traded it for an ls vtec. i love the car and plan on keeping it until it gets stolen. hopefully not. i have a b18b1 block and a gsr head not sure the year or mileage on them. the only thing that im wondering about is he used a b16a ecu..i dont think its even chipped. is that a problem that i might have? the idol sometime goes so low it sounds like it might shut off. im not sure if thats the reason. any info on this would help a lot thanks.
yes get a jdm obd1 gsr ecu and it will plug in directly.. if your idle is low though it sounds like you have something else going on. check idle screw as stated above and swap the ecu and go from there
as long as the ecu is obd1 its plug and play. as of the ecu ive heard of people using p28 for that set up and you gotta get it chipped and tuned. either way getting the p72 ecu you should chip and tune it so you have the maximum power achieved from your set up
yea i just need to find that ecu now. im going to check out clm motorsports in newark, i heard they where the best for hondas. anyone else been there?
go to swapshopracing . com they do a good job making sure they help you out with the right part and advice... they even have good prices on parts to be honest
