my quest into the 10s and through my first event
Old May 18, 2010 | 04:14 PM
germanegturbo's Avatar
Default my quest into the 10s and through my first event
car made 522 whp on only 15 psi and is being runn off the wastegate so the car spunn alot and would lock me out of 2nd(single disk ftl)but other than that i am very happy with the new set up..car got put together last tuesday..tuned wendsday..track that same night..fixed smaller issues thursdays and then back to practice friday..and then the event..and nothing major broke(clutch started creeping). boost by gear coming soon
car is going all over the place from 10.9 to 11.2
vid is up
http://www.youtube.com/watch?v=gv58B7pQF9s
Old May 18, 2010 | 04:22 PM
DeLucia's Avatar
Default Re: my quest into the 10s and through my first event
Info on the setup? 522 @ 15psi is awesome power
Old May 18, 2010 | 04:25 PM
its a 84mm aebs sleeved block with wisco 10 to1 comp ls crank b16 head with farrera valves,supertec springs..port and polish..3 andle valve jobs and skunk 2 pro 1s..topmound with a billet 62/62 none ball bearing
Old May 18, 2010 | 05:00 PM
ysofasts2k's Avatar
mike u lucky my car was broken i woulda got off in that ***, lol car looks beautiful sounds very nice, congrats though kid, rep for the home team.
ysofasts2k's Avatar
P.S. OUR COUPE SQUAD LOOKS VERY NICE
Old May 18, 2010 | 05:05 PM
Turbo_TONY's Avatar
id love to see the dyno graph. congrats on the times!
Old May 18, 2010 | 08:38 PM
b20vtech's Avatar
what engine management?
Old May 18, 2010 | 08:58 PM
AR Performance's Avatar
nice pics mike
Old May 18, 2010 | 10:00 PM
Blueberry1320's Avatar
Nice
Old May 19, 2010 | 11:48 AM
vid is up
Old May 19, 2010 | 12:52 PM
AddictsRacing's Avatar
Your car is making some awesome power, not bad times either! Congrats!
Old May 19, 2010 | 02:36 PM
DeLucia's Avatar
Just because its a single disc clutch doesnt mean thats the problem for you not being able to shift. I had the same problem with my stage 5, i just adjusted the master cylinder shaft on the clutch pedal so it would push it in further. Its prolly just not being pushed in far enough and not fully disengaging the clutch
Old May 19, 2010 | 05:01 PM
turbociv910's Avatar
522 at 15 psi. sounds like something mase would say
Old May 19, 2010 | 05:24 PM
Kyle R's Avatar
Originally Posted by Blueberry1320
Nice
Old May 19, 2010 | 06:10 PM
thank you
well i after 10 ish track passes it started happening and we tryed adjustin it..the clutch had been repuked but is about almost 2 years old plus i wanna go up to the 650 hp rang in a few months so ill just get it over with and go twin dosk
or fred from the hpc lol
Old May 19, 2010 | 07:01 PM
d112crzy's Avatar
Looks like you need some mounts, bad!
Impressive numbers though. I know the vid says full weight, but what exactly is that weight?
Old May 19, 2010 | 07:47 PM
actually i have hasports..the rear mount was bad but it got fixed and well the car doesnt have ac or ps but im sure the turbo kit adds back on to it..what i meant by full weight is nothing was cut out or taken out minus the bumper support..and never weighed her in
Old May 19, 2010 | 10:20 PM
13173's Avatar
What is that in the intake tube right at the beginning when your car is on the dyno? Looks like water or something in the tube where the headlight is supposed to be.
Old May 19, 2010 | 10:26 PM
jdm inc's Avatar
awesome! Congrats on the time! car looks good!
Old May 19, 2010 | 11:41 PM
OMG B16's Avatar
Hondata S300.
The car makes good power because everything works well together. I had a similar set-up and it made 499whp @ 13psi.
Congrats on reaching your goals Mike. 9's are next!
Old May 20, 2010 | 12:10 AM
jdm inc's Avatar
what turbo are you running?
Old May 20, 2010 | 12:44 AM
its a lil water..we were spraying water on things like the intak,radiator,intercooler,intake mani after a few pulls to cool it off
Originally Posted by OMG B16
Hondata S300.
hopefully son lol gotta learn how to drive first lol
billet 6262 non ball bearing
Dat1BVtecN
Apr 28, 2009 06:33 AM
Atomkane
Oct 8, 2007 10:49 AM
Smitdog
Apr 11, 2005 07:40 AM
TeH PLAYA
Mar 22, 2005 10:45 AM
14eight
May 18, 2003 04:50 PM
