FS: stock H23a1 AND F22a6 part-out!
Got random parts layin around. Located in North Jersey, buyer pays shipping and Paypal fees. All prices are without shipping.
H23a1 parts:
-Block (crank snapped in half, destroyed some journals. can be re-align bored/honed to 55mm for F23/H22 cranks) $50
-oil cooler $20
-water pipe $10
-drivers side engine bracket x2 $10/each
-balancer shafts (front and rear) $30 for both
-B-shafts gears/casing/belt $5/each
-OBD2 lower timing gear $5
-lower timing cover $10
-EGR valves x3 $15/each
-EGR solenoid $10
-EVAP canister $10
-rear engine cover x2 $10
-oil baffle x2 $5
-oil pickup x2 $15
-dipstick x2 $10
-oil pan $30
-megan header/downpipe $40
-lower intake manifold/thermostat housing x2 $50/each
-fuel rail/FPR $25
-IAB plate $20
-external coils x3 $40/each
-resistor box $45
-power steering pump/bracket/cooler/reservoir $40/$10/$15/$15
-air conditioning compressor/condensor/bracket/canister $45/$35/$10/$10
F22a6 parts:
-auto engine harness (4 connectors are cut off, i only know 1 is the VSS) $60
-head, with valvetrain and valve cover $100
-camshaft, with cam gear $80
-pistons with rods $90
-stock header/heat shield $40
-entire intake manifold $60
-alternator $30
-PS pump $25
-PS/AC/alt brackets $10/each
-front mount $10
might have some other parts that i forgot about. feel free to ask.
H23a1 parts:
-oil cooler $20
-water pipe $10
-EGR solenoid $10
-EVAP canister $10
-oil baffle x2 $5
-oil pickup x2 $15
-dipstick x2 $10
-oil pan $30
-fuel rail/FPR $25
-IAB plate $20
-resistor box $45
F22a6 parts:
-alternator $30
-PS pump $25
-front mount $10
